[PATCH] leon, spwtdp: Initial driver commit
Daniel Hellstrom
daniel at gaisler.com
Fri Oct 5 06:57:48 UTC 2018
bsps/sparc/headers.am | 1 +
bsps/sparc/include/bsp/spwtdp.h | 320 ++++++++++
bsps/sparc/include/drvmgr/ambapp_bus.h | 1 +
bsps/sparc/shared/spw/spwtdp.c | 1022 ++++++++++++++++++++++++++++++
c/src/lib/libbsp/sparc/leon2/Makefile.am | 4 +
c/src/lib/libbsp/sparc/leon3/Makefile.am | 5 +
cpukit/include/drvmgr/drvmgr_confdefs.h | 4 +
7 files changed, 1357 insertions(+)
create mode 100644 bsps/sparc/include/bsp/spwtdp.h
create mode 100644 bsps/sparc/shared/spw/spwtdp.c
diff --git a/bsps/sparc/headers.am b/bsps/sparc/headers.am
index 5b4236e..4c6efb8 100644
--- a/bsps/sparc/headers.am
+++ b/bsps/sparc/headers.am
@@ -61,6 +61,7 @@ include_bsp_HEADERS += ../../../../../bsps/sparc/include/bsp/pcif.h
include_bsp_HEADERS += ../../../../../bsps/sparc/include/bsp/satcan.h
include_bsp_HEADERS += ../../../../../bsps/sparc/include/bsp/spictrl.h
include_bsp_HEADERS += ../../../../../bsps/sparc/include/bsp/spwcuc.h
+include_bsp_HEADERS += ../../../../../bsps/sparc/include/bsp/spwtdp.h
include_bsp_HEADERS += ../../../../../bsps/sparc/include/bsp/tlib.h
include_drvmgrdir = $(includedir)/drvmgr
diff --git a/bsps/sparc/include/bsp/spwtdp.h b/bsps/sparc/include/bsp/spwtdp.h
new file mode 100644
index 0000000..b2fa298
--- /dev/null
+++ b/bsps/sparc/include/bsp/spwtdp.h
@@ -0,0 +1,320 @@
+/* SPWTDP - SpaceWire Time Distribution Protocol. The driver provides
+ * device discovery and interrupt management.
+ * COPYRIGHT (c) 2017.
+ * Cobham Gaisler AB
+ * http://www.rtems.com/license/LICENSE.
+#ifndef __SPWTDP_H__
+#define __SPWTDP_H__
+#ifdef __cplusplus
+extern "C" {
+#endif
+#define SPWTDP_ERR_OK 0
+#define SPWTDP_ERR_EINVAL -1
+#define SPWTDP_ERR_ERROR -2
+#define SPWTDP_ERR_NOINIT -3
+/* Maximum number of SPWTDP devices supported by driver */
+#define SPWTDP_MAX 2
+/* SPWTDP Register layout */
+struct spwtdp_regs {
+ volatile unsigned int conf[4]; /* 0x000-0x00C */
+ volatile unsigned int stat[4]; /* 0x010-0x01C */
+ volatile unsigned int cmd_ctrl; /* 0x020 */
+ volatile unsigned int cmd_et[5]; /* 0x024-0x034 */
+ volatile unsigned int resv1[2]; /* 0x038-0x03C */
+ volatile unsigned int dat_ctrl; /* 0x040 */
+ volatile unsigned int dat_et[5]; /* 0x044-0x054 */
+ volatile unsigned int resv2[2]; /* 0x058-0x05C */
+ volatile unsigned int ts_rx_ctrl; /* 0x060 */
+ volatile unsigned int ts_rx_et[5]; /* 0x064-0x074 */
+ volatile unsigned int resv3[2]; /* 0x078-0x07C */
+ volatile unsigned int ts_tx_ctrl; /* 0x080 */
+ volatile unsigned int ts_tx_et[5]; /* 0x084-0x094 */
+ volatile unsigned int resv4[2]; /* 0x098 */
+ volatile unsigned int lat_ctrl; /* 0x0A0 */
+ volatile unsigned int lat_et[5]; /* 0x0A4-0x0B4 */
+ volatile unsigned int resv5[2]; /* 0x0B8-0x0BC */
+ volatile unsigned int ien; /* 0x0C0 */
+ volatile unsigned int ists; /* 0x0C4 */
+ volatile unsigned int dlycnt; /* 0x0C8 */
+ volatile unsigned int dissync; /* 0x0CC */
+ volatile unsigned int resv6[12]; /* 0x0D0-0x0FC */
+ volatile unsigned int edmask[4]; /* 0x100-0x10C */
+ struct {
+ volatile unsigned int ctrl; /* 0x110, 0x130, 0x150, 0x170 */
+ volatile unsigned int et[5]; /* 0x114-0x124, 0x134-0x144, 0x154-0x164, 0x174-0x184, */
+ volatile unsigned int resv0[2]; /* 0x128-0x12C, 0x148-0x14C, 0x168-0x16C, 0x188-0x18C, */
+ } edat[4]; /* 0x110-0x18C */
+ volatile unsigned int resv7[4]; /* 0x190-0x19C */
+ volatile unsigned int pulse[8]; /* 0x1A0-0x1BC */
+ volatile unsigned int resv8[16]; /* 0x1C0-0x1FC */
+ * Configuration register definitions
+#define CONF0_JE (0x1 << CONF0_JE_BIT)
+#define CONF0_ST (0x1 << CONF0_ST_BIT)
+#define CONF0_EP (0x1 << CONF0_EP_BIT)
+#define CONF0_ET (0x1 << CONF0_ET_BIT)
+#define CONF0_SP (0x1 << CONF0_SP_BIT)
+#define CONF0_SE (0x1 << CONF0_SE_BIT)
+#define CONF0_LE (0x1 << CONF0_LE_BIT)
+#define CONF0_AE (0x1 << CONF0_AE_BIT)
+#define CONF0_MAP (0x1f << CONF0_MAP_BIT)
+#define CONF0_TD (0x1 << CONF0_TD_BIT)
+#define CONF0_MU (0x1 << CONF0_MU_BIT)
+#define CONF0_SEL (0x3 << CONF0_SEL_BIT)
+#define CONF0_ME (0x1 << CONF0_ME_BIT)
+#define CONF0_RE (0x1 << CONF0_RE_BIT)
+#define CONF0_TE (0x1 << CONF0_TE_BIT)
+#define CONF0_RS (0x1 << CONF0_RS_BIT)
+#define CONF0_JE_BIT 24
+#define CONF0_ST_BIT 21
+#define CONF0_EP_BIT 20
+#define CONF0_ET_BIT 19
+#define CONF0_SP_BIT 18
+#define CONF0_SE_BIT 17
+#define CONF0_LE_BIT 16
+#define CONF0_AE_BIT 15
+#define CONF0_MAP_BIT 8
+#define CONF0_TD_BIT 7
+#define CONF0_MU_BIT 6
+#define CONF0_SEL_BIT 4
+#define CONF0_ME_BIT 3
+#define CONF0_RE_BIT 2
+#define CONF0_TE_BIT 1
+#define CONF0_RS_BIT 0
+#define CONF1_FSINC (0x3fffffff << CONF1_FSINC_BIT)
+#define CONF1_FSINC_BIT 0
+#define CONF2_CV (0xffffff << CONF2_CV_BIT)
+#define CONF2_ETINC (0xff << CONF2_ETINC_BIT)
+#define CONF2_CV_BIT 8
+#define CONF2_ETINC_BIT 0
+#define CONF3_OUTPORT (0xf << CONF3_OUTPORT_BIT)
+#define CONF3_INPORT (0xf << CONF3_INPORT_BIT)
+#define CONF3_STM (0x3f << CONF3_STM_BIT)
+#define CONF3_DI64R (0x1 << CONF3_DI64R_BIT)
+#define CONF3_DI64T (0x1 << CONF3_DI64T_BIT)
+#define CONF3_DI64 (0x1 << CONF3_DI64_BIT)
+#define CONF3_DI (0x1 << CONF3_DI_BIT)
+#define CONF3_INRX (0x1f << CONF3_INRX_BIT)
+#define CONF3_INTX (0x1f << CONF3_INTX_BIT)
+#define CONF3_OUTPORT_BIT 28
+#define CONF3_INPORT_BIT 24
+#define CONF3_STM_BIT 16
+#define CONF3_DI64R_BIT 13
+#define CONF3_DI64T_BIT 12
+#define CONF3_DI64_BIT 11
+#define CONF3_DI_BIT 10
+#define CONF3_INRX_BIT 5
+#define CONF3_INTX_BIT 0
+ * Control register definitions
+#define CTRL_NC (0x1 << CTRL_NC_BIT)
+#define CTRL_IS (0x1 << CTRL_IS_BIT)
+#define CTRL_SPWTC (0xff << CTRL_SPWTC_BIT)
+#define CTRL_CPF (0xffff << CTRL_CPF_BIT)
+#define CTRL_NC_BIT 31
+#define CTRL_IS_BIT 30
+#define CTRL_SPWTC_BIT 16
+#define CTRL_CPF_BIT 0
+ * Interrupt register definition
+#define SPWTDP_IRQ_S (0x1 << SPWTDP_IRQ_S_BIT)
+#define SPWTDP_IRQ_TR (0x1 << SPWTDP_IRQ_TR_BIT)
+#define SPWTDP_IRQ_TM (0x1 << SPWTDP_IRQ_TM_BIT)
+#define SPWTDP_IRQ_TT (0x1 << SPWTDP_IRQ_TT_BIT)
+#define SPWTDP_IRQ_DIR (0x1 << SPWTDP_IRQ_DIR_BIT)
+#define SPWTDP_IRQ_DIT (0x1 << SPWTDP_IRQ_DIT_BIT)
+#define SPWTDP_IRQ_EDI0 (0x1 << SPWTDP_IRQ_EDI0_BIT)
+#define SPWTDP_IRQ_EDI1 (0x1 << SPWTDP_IRQ_EDI1_BIT)
+#define SPWTDP_IRQ_EDI2 (0x1 << SPWTDP_IRQ_EDI2_BIT)
+#define SPWTDP_IRQ_EDI3 (0x1 << SPWTDP_IRQ_EDI3_BIT)
+#define SPWTDP_IRQ_SET (0x1 << SPWTDP_IRQ_SET_BIT)
+#define SPWTDP_IRQ_P0 (0x1 << SPWTDP_IRQ_P0_BIT)
+#define SPWTDP_IRQ_P1 (0x1 << SPWTDP_IRQ_P1_BIT)
+#define SPWTDP_IRQ_P2 (0x1 << SPWTDP_IRQ_P2_BIT)
+#define SPWTDP_IRQ_P3 (0x1 << SPWTDP_IRQ_P3_BIT)
+#define SPWTDP_IRQ_P4 (0x1 << SPWTDP_IRQ_P4_BIT)
+#define SPWTDP_IRQ_P5 (0x1 << SPWTDP_IRQ_P5_BIT)
+#define SPWTDP_IRQ_P6 (0x1 << SPWTDP_IRQ_P6_BIT)
+#define SPWTDP_IRQ_P7 (0x1 << SPWTDP_IRQ_P7_BIT)
+#define SPWTDP_IRQ_NCTC (0x1 << SPWTDP_IRQ_NCTC_BIT)
+#define SPWTDP_IRQ_WCLEAR \
+ (SPWTDP_IRQ_S | SPWTDP_IRQ_TR | SPWTDP_IRQ_TM | \
+ SPWTDP_IRQ_TT | SPWTDP_IRQ_DIR | SPWTDP_IRQ_DIT | SPWTDP_IRQ_EDI0 | \
+ SPWTDP_IRQ_EDI1 | SPWTDP_IRQ_EDI2 | SPWTDP_IRQ_EDI3 | SPWTDP_IRQ_SET |\
+ SPWTDP_IRQ_P0 | SPWTDP_IRQ_P1 | SPWTDP_IRQ_P2 | SPWTDP_IRQ_P3 | \
+ SPWTDP_IRQ_P4 | SPWTDP_IRQ_P5 | SPWTDP_IRQ_P6 | SPWTDP_IRQ_P7 | \
+ SPWTDP_IRQ_NCTC)
+#define SPWTDP_IRQ_ALL (SPWTDP_IRQ_WCLEAR)
+#define SPWTDP_IRQ_S_BIT 0
+#define SPWTDP_IRQ_TR_BIT 1
+#define SPWTDP_IRQ_TM_BIT 2
+#define SPWTDP_IRQ_TT_BIT 3
+#define SPWTDP_IRQ_DIR_BIT 4
+#define SPWTDP_IRQ_DIT_BIT 5
+#define SPWTDP_IRQ_EDI0_BIT 6
+#define SPWTDP_IRQ_EDI1_BIT 7
+#define SPWTDP_IRQ_EDI2_BIT 8
+#define SPWTDP_IRQ_EDI3_BIT 9
+#define SPWTDP_IRQ_SET_BIT 10
+#define SPWTDP_IRQ_P0_BIT 11
+#define SPWTDP_IRQ_P1_BIT 12
+#define SPWTDP_IRQ_P2_BIT 13
+#define SPWTDP_IRQ_P3_BIT 14
+#define SPWTDP_IRQ_P4_BIT 15
+#define SPWTDP_IRQ_P5_BIT 16
+#define SPWTDP_IRQ_P6_BIT 17
+#define SPWTDP_IRQ_P7_BIT 18
+#define SPWTDP_IRQ_NCTC_BIT 19
+/* Register the SPWTDP Driver to the Driver Manager */
+void spwtdp_register_drv(void);
+/* Open a SPWTDP device by registration order index. A SPWTDP device can only by
+ * opened once. The handle returned must be used as the input parameter 'spwtdp'
+ * in the rest of the calls in the function interface.
+extern void *spwtdp_open(int dev_no);
+/* Close a previously opened SPWTDP device */
+extern int spwtdp_close(void *spwtdp);
+/* Reset SPWTDP Core */
+extern int spwtdp_reset(void *spwtdp);
+/* Setup the frequency configuration registers */
+extern int spwtdp_freq_setup(void *spwtdp, uint32_t fsinc, uint32_t cv,
+ uint8_t etinc);
+/* Unmask Interrupts at Interrupt controller */
+extern int spwtdp_interrupt_unmask(void *spwtdp, uint32_t irqmask);
+/* Mask Interrupts at Interrupt controller */
+extern int spwtdp_interrupt_mask(void *spwtdp, uint32_t irqmask);
+/* Function ISR callback prototype
+ * ists - Interrupt STatus register of the SPWTDP core read by ISR
+ * data - Custom data provided by user
+typedef void (*spwtdp_isr_t)(unsigned int ists, void *data);
+/* Register an Interrupt handler and custom data, the function call is
+ * removed by calling unregister function.
+extern int spwtdp_isr_register(void *spwtdp, spwtdp_isr_t isr, void *data);
+/* Unregister an Interrupt handler */
+extern int spwtdp_isr_unregister(void *spwtdp);
+/* Get and clear interrupt status */
+extern int spwtdp_interrupt_status(void *spwtdp, uint32_t *sts,
+ uint32_t clrmask);
+/* Setup Initiator and target */
+#define SPWTDP_TDP_ENABLE CONF0_TD
+#define SPWTDP_TDP_DISABLE 0
+#define SPWTDP_LATENCY_ENABLE CONF0_LE
+#define SPWTDP_LATENCY_DISABLE 0
+#define SPWTDP_EXTET_INC_POLARITY_RISING CONF0_EP
+#define SPWTDP_EXTET_INC_POLARITY_FALLING 0
+#define SPWTDP_EXTET_INC_ENABLE CONF0_ET
+#define SPWTDP_EXTET_INC_DISABLE 0
+#define SPWTDP_EXTET_POLARITY_RISING CONF0_SP
+#define SPWTDP_EXTET_POLARITY_FALLING 0
+#define SPWTDP_EXTET_ENABLE CONF0_SE
+#define SPWTDP_EXTET_DISABLE 0
+#define SPWTDP_TARGET_SPWSYNC_ENABLE CONF0_ST
+#define SPWTDP_TARGET_SPWSYNC_DISABLE 0
+#define SPWTDP_TARGET_JITTERC_ENABLE CONF0_JE
+#define SPWTDP_TARGET_JITTERC_DISABLE 0
+#define SPWTDP_TARGET_MITIGATION_ENABLE CONF0_ME
+#define SPWTDP_TARGET_MITIGATION_DISABLE 0
+extern int spwtdp_initiator_conf(void *spwtdp, uint8_t mapping,
+ uint32_t options);
+extern int spwtdp_target_conf(void *spwtdp, uint8_t mapping, uint32_t options);
+/* Setup Initiator and target dist interrupts */
+extern int spwtdp_initiator_int_conf(void *spwtdp, uint8_t stm, uint8_t inrx,
+ uint8_t intx);
+#define SPWTDP_TARGET_DISTINT_INTACK CONF3_DI
+#define SPWTDP_TARGET_DISTINT_INT 0
+extern int spwtdp_target_int_conf(void *spwtdp, uint8_t inrx, uint8_t intx,
+/* Enable Initiator and target */
+extern int spwtdp_initiator_enable(void *spwtdp);
+extern int spwtdp_target_enable(void *spwtdp);
+/* Disable Initiator and target */
+extern int spwtdp_initiator_disable(void *spwtdp);
+extern int spwtdp_target_disable(void *spwtdp);
+/* Get and clear status */
+extern int spwtdp_status(void *spwtdp, uint32_t *sts, uint32_t clrmask);
+/* Define time struct */
+/* Length of the max data sample (136 bits), aligned to the next 32-bit word
+ * (160 bits=20 byte=5 words)
+#define SPWTDP_TIME_DATA_LENGTH 20
+struct spwtdp_time_t {
+ uint8_t data[SPWTDP_TIME_DATA_LENGTH];
+ uint32_t preamble;
+typedef struct spwtdp_time_t spwtdp_time_t;
+/* Get datation elapsed time */
+extern int spwtdp_dat_et_get(void *spwtdp, spwtdp_time_t * val);
+extern int spwtdp_tsrx_et_get(void *spwtdp, spwtdp_time_t * val);
+extern int spwtdp_tstx_et_get(void *spwtdp, spwtdp_time_t * val);
+extern int spwtdp_lat_et_get(void *spwtdp, spwtdp_time_t * val);
+extern int spwtdp_cmd_et_get(void *spwtdp, spwtdp_time_t * val);
+/* Configure TSTX */
+extern int spwtdp_initiator_tstx_conf(void *spwtdp, uint8_t tstc);
+/* Manage control register */
+extern int spwtdp_initiator_cmd_et_set(void *spwtdp, spwtdp_time_t val);
+extern int spwtdp_initiator_cmd_spwtc_set(void *spwtdp, uint8_t spwtc);
+#define SPWTDP_TARGET_CTRL_NEWCOMMAND_ENABLE CTRL_NC
+#define SPWTDP_TARGET_CTRL_NEWCOMMAND_DISABLE 0
+#define SPWTDP_TARGET_CTRL_INIT CTRL_IS
+#define SPWTDP_TARGET_CTRL_SYNC 0
+extern int spwtdp_target_cmd_conf(void *spwtdp, uint8_t spwtc, uint16_t cpf,
+/* Get precision */
+extern int spwtdp_precision_get(void *spwtdp, uint8_t *fine, uint8_t *coarse);
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/bsps/sparc/include/drvmgr/ambapp_bus.h b/bsps/sparc/include/drvmgr/ambapp_bus.h
index d034aae..94a7fe2 100644
--- a/bsps/sparc/include/drvmgr/ambapp_bus.h
+++ b/bsps/sparc/include/drvmgr/ambapp_bus.h
@@ -59,6 +59,7 @@ extern "C" {
#define DRIVER_AMBAPP_GAISLER_L2CACHE_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_L2CACHE)
#define DRIVER_AMBAPP_GAISLER_MEMSCRUB_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_MEMSCRUB)
#define DRIVER_AMBAPP_GAISLER_L4STAT_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_L4STAT)
+#define DRIVER_AMBAPP_GAISLER_SPWTDP_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_SPWTDP)
/*** ESA Hardware Device Driver IDs ***/
#define DRIVER_AMBAPP_ESA_MCTRL_ID DRIVER_AMBAPP_ID(VENDOR_ESA, ESA_MCTRL)
diff --git a/bsps/sparc/shared/spw/spwtdp.c b/bsps/sparc/shared/spw/spwtdp.c
index 0000000..cf5b3af
--- /dev/null
+++ b/bsps/sparc/shared/spw/spwtdp.c
@@ -0,0 +1,1022 @@
+#include <stdio.h>
+#include <stdlib.h>
+#include <stddef.h>
+#include <rtems.h>
+#include <rtems/bspIo.h>
+#include <drvmgr/drvmgr.h>
+#include <ambapp.h>
+#include <drvmgr/ambapp_bus.h>
+#include <bsp.h>
+#include <bsp/spwtdp.h>
+/* Use interrupt lock privmitives compatible with SMP defined in
+ * RTEMS 4.11.99 and higher.
+#if (((__RTEMS_MAJOR__ << 16) | (__RTEMS_MINOR__ << 8) | __RTEMS_REVISION__) >= 0x040b63)
+/* map via rtems_interrupt_lock_* API: */
+#define SPIN_DECLARE(lock) RTEMS_INTERRUPT_LOCK_MEMBER(lock)
+#define SPIN_INIT(lock, name) rtems_interrupt_lock_initialize(lock, name)
+#define SPIN_LOCK(lock, level) rtems_interrupt_lock_acquire_isr(lock, &level)
+#define SPIN_LOCK_IRQ(lock, level) rtems_interrupt_lock_acquire(lock, &level)
+#define SPIN_UNLOCK(lock, level) rtems_interrupt_lock_release_isr(lock, &level)
+#define SPIN_UNLOCK_IRQ(lock, level) rtems_interrupt_lock_release(lock, &level)
+#define SPIN_IRQFLAGS(k) rtems_interrupt_lock_context k
+#define SPIN_ISR_IRQFLAGS(k) SPIN_IRQFLAGS(k)
+#else
+/* maintain single-core compatibility with older versions of RTEMS: */
+#define SPIN_DECLARE(name)
+#define SPIN_LOCK_IRQ(lock, level) rtems_interrupt_disable(level)
+#define SPIN_UNLOCK_IRQ(lock, level) rtems_interrupt_enable(level)
+#define SPIN_IRQFLAGS(k) rtems_interrupt_level k
+#ifdef RTEMS_SMP
+#error SMP mode not compatible with these interrupt lock primitives
+#endif
+#endif
+/*#define STATIC*/
+#define STATIC static
+/*#define INLINE*/
+#define INLINE inline
+/*#define UNUSED*/
+#define UNUSED __attribute__((unused))
+#define DEBUG 1
+#ifdef DEBUG
+#define DBG(x...) printf(x)
+#else
+#define DBG(x...)
+#endif
+/* Memory and HW Registers Access routines. All 32-bit access routines */
+#define REG_WRITE(addr, val) \
+ (*(volatile unsigned int *)(addr) = (unsigned int)(val))
+#define REG_READ(addr) (*(volatile unsigned int *)(addr))
+ * DEFINED in header
+ * TSTX Control register definitions
+#define TSTXCTRL_TSTC (0xff<<TSTXCTRL_TSTC_BIT)
+#define ETCTRL_PF (0xffff<<ETCTRL_PF_BIT)
+#define TSTXCTRL_TSTC_BIT 24
+#define ETCTRL_PF_BIT 0
+#define DEVNAME_LEN 11
+/* Private structure of SPWTDP driver. */
+struct spwtdp_priv {
+ char devname[DEVNAME_LEN];
+ struct drvmgr_dev *dev; /* Device */
+ struct spwtdp_regs *regs;
+ int open;
+ int index;
+ int initiator; /* Initiator configured */
+ int target; /* Target configured */
+ int freq; /* Frequency configured */
+ /* Spin-lock ISR protection */
+ SPIN_DECLARE(devlock);
+ /* Driver semaphore */
+ rtems_id sem;
+ spwtdp_isr_t isr;
+ void * isr_arg;
+int spwtdp_count = 0;
+static struct spwtdp_priv *priv_tab[SPWTDP_MAX];
+STATIC void spwtdp_isr(void *data);
+STATIC int spwtdp_hw_reset(struct spwtdp_priv *priv);
+STATIC int spwtdp_init2(struct drvmgr_dev *dev);
+struct drvmgr_drv_ops spwtdp_ops =
+ {NULL, spwtdp_init2, NULL, NULL},
+ NULL,
+ NULL
+struct amba_dev_id spwtdp_ids[] =
+ {VENDOR_GAISLER, GAISLER_SPWTDP},
+ {0, 0} /* Mark end of table */
+struct amba_drv_info spwtdp_drv_info =
+ DRVMGR_OBJ_DRV, /* Driver */
+ NULL, /* Next driver */
+ NULL, /* Device list */
+ DRIVER_AMBAPP_GAISLER_SPWTDP_ID,/* Driver ID */
+ "SPWTDP_DRV", /* Driver Name */
+ DRVMGR_BUS_TYPE_AMBAPP, /* Bus Type */
+ &spwtdp_ops,
+ NULL, /* Funcs */
+ 0, /* No devices yet */
+ sizeof(struct spwtdp_priv), /* Let DrvMgr allocate priv */
+ &spwtdp_ids[0]
+/* Register the SPWTDP Driver */
+ DBG("Registering SPWTDP driver\n");
+ drvmgr_drv_register(&spwtdp_drv_info.general);
+STATIC int spwtdp_init(struct spwtdp_priv *priv)
+ struct amba_dev_info *ainfo = priv->dev->businfo;
+ struct ambapp_apb_info *apb;
+ /* Get device information from AMBA PnP information */
+ if (ainfo == NULL) {
+ return -1;
+ apb = ainfo->info.apb_slv;
+ priv->regs = (struct spwtdp_regs *)apb->start;
+ spwtdp_hw_reset(priv);
+ /* Only support 56 bits counter */
+ if (REG_READ(&priv->regs->dat_ctrl) != 0x2f00) {
+ DBG("SPWTDP only supports 56 bit precission counters.\n");
+ return -1;
+ DBG("SPWTDP driver initialized\n");
+ return 0;
+/*** INTERFACE TO DRIVER MANAGER ***/
+ int status;
+ struct spwtdp_priv *priv;
+ DBG("SPWTDP[%d] on bus %s\n", dev->minor_drv, dev->parent->dev->name);
+ if (spwtdp_count >= SPWTDP_MAX)
+ return DRVMGR_ENORES;
+ priv = dev->priv;
+ if (priv == NULL)
+ return DRVMGR_NOMEM;
+ /* Register device */
+ priv->dev = dev;
+ priv->index = spwtdp_count;
+ priv_tab[priv->index] = priv;
+ snprintf(priv->devname, DEVNAME_LEN, "spwtdp%01u", priv->index);
+ spwtdp_count++;
+ /* Initialize Semaphore */
+ if (rtems_semaphore_create(
+ rtems_build_name('S', 'T', 'P', '0' + priv->index), 1,
+ RTEMS_FIFO | RTEMS_SIMPLE_BINARY_SEMAPHORE | \
+ RTEMS_NO_INHERIT_PRIORITY | RTEMS_LOCAL | \
+ RTEMS_NO_PRIORITY_CEILING, 0, &priv->sem) != RTEMS_SUCCESSFUL) {
+ priv->sem = RTEMS_ID_NONE;
+ return DRVMGR_FAIL;
+ /* Initialize SPWTDP Hardware */
+ status = spwtdp_init(priv);
+ if (status) {
+ printk("Failed to initialize spwtdp driver %d\n", status);
+ return -1;
+ return DRVMGR_OK;
+/* Hardware Reset of SPWTDP */
+ int i = 1000;
+ SPIN_IRQFLAGS(irqflags);
+ SPIN_LOCK_IRQ(&priv->devlock, irqflags);
+ /* Clear interrupts */
+ REG_WRITE(&priv->regs->ists, SPWTDP_IRQ_WCLEAR);
+ /* Reset the SPWTDP core */
+ REG_WRITE(&priv->regs->conf[0], CONF0_RS);
+ /* Wait for reset */
+ while ((REG_READ(&priv->regs->conf[0]) & CONF0_RS) && (i > 0)) {
+ i--;
+ SPIN_UNLOCK_IRQ(&priv->devlock, irqflags);
+ return ((i > 0)? SPWTDP_ERR_OK : SPWTDP_ERR_ERROR);
+int spwtdp_reset(void *spwtdp)
+ struct spwtdp_priv *priv = (struct spwtdp_priv *)spwtdp;
+ /* Check priv and unregister isr */
+ int ret = spwtdp_isr_unregister(spwtdp);
+ if (ret != SPWTDP_ERR_OK)
+ return ret;
+ priv->initiator=0;
+ priv->target=0;
+ priv->freq=0;
+ return spwtdp_hw_reset(priv);
+void *spwtdp_open(int dev_no)
+ if (dev_no >= spwtdp_count)
+ return NULL;
+ /* Get Device */
+ priv = priv_tab[dev_no];
+ if ((priv == NULL)||(priv->open == 1)) {
+ return NULL;
+ /* Set initial state of software */
+ priv->open = 1;
+ return priv;
+int spwtdp_close(void *spwtdp)
+ /* Check priv and reset core */
+ int ret = spwtdp_reset(spwtdp);
+ return ret;
+ priv->open = 0;
+ return SPWTDP_ERR_OK;
+int spwtdp_freq_setup(void *spwtdp, uint32_t fsinc, uint32_t cv, uint8_t etinc)
+ /* Check priv */
+ if (priv == NULL)
+ return SPWTDP_ERR_NOINIT;
+ if (priv->open == 0)
+ return SPWTDP_ERR_EINVAL;
+ /* Take SPWTDP lock - Wait until we get semaphore */
+ if (rtems_semaphore_obtain(priv->sem, RTEMS_WAIT, RTEMS_NO_TIMEOUT)
+ != RTEMS_SUCCESSFUL)
+ return SPWTDP_ERR_ERROR;
+ REG_WRITE(&priv->regs->conf[1], fsinc & CONF1_FSINC);
+ REG_WRITE(&priv->regs->conf[2],
+ ((cv<<CONF2_CV_BIT) & CONF2_CV) |
+ ((uint32_t)etinc & CONF2_ETINC));
+ rtems_semaphore_release(priv->sem);
+ priv->freq = 1;
+#define CONF0_INI_MASK (CONF0_EP|CONF0_ET|CONF0_SP|CONF0_SE|CONF0_LE| \
+ CONF0_TD)
+int spwtdp_initiator_conf(void *spwtdp, uint8_t mapping, uint32_t options)
+ /* Check priv */
+ if (priv == NULL)
+ /* Check if configured as target */
+ if (priv->target == 1)
+ unsigned int conf0 = REG_READ(&priv->regs->conf[0]);
+ conf0 &= ~(CONF0_INI_MASK|CONF0_MAP);
+ conf0 | (options & CONF0_INI_MASK) |
+ (((uint32_t)mapping << CONF0_MAP_BIT) & CONF0_MAP));
+ priv->initiator = 1;
+#define CONF0_TAR_MASK (CONF0_JE|CONF0_ST|CONF0_EP|CONF0_ET|CONF0_SP| \
+ CONF0_SE|CONF0_LE|CONF0_TD|CONF0_ME)
+int spwtdp_target_conf(void *spwtdp, uint8_t mapping, uint32_t options)
+ /* Check priv */
+ if (priv == NULL)
+ /* Check if configured as initiator */
+ if (priv->initiator == 1)
+ conf0 &= ~(CONF0_TAR_MASK|CONF0_MAP);
+ conf0 | (options & CONF0_TAR_MASK) |
+int spwtdp_initiator_int_conf(void *spwtdp, uint8_t stm, uint8_t inrx,
+ uint8_t intx)
+ /* Check priv */
+ if (priv == NULL)
+ if (priv->initiator != 1)
+ REG_WRITE(&priv->regs->conf[3],
+ (((uint32_t)stm << CONF3_STM_BIT) & CONF3_STM) |
+ (((uint32_t)inrx << CONF3_INRX_BIT) & CONF3_INRX) |
+ (((uint32_t)intx << CONF3_INTX_BIT) & CONF3_INTX));
+int spwtdp_target_int_conf(void *spwtdp, uint8_t inrx, uint8_t intx,
+ uint32_t options)
+ /* Check priv */
+ if (priv == NULL) {
+ if (priv->target != 1)
+ (options & CONF3_DI) |
+int spwtdp_initiator_enable(void *spwtdp)
+ /* Check priv */
+ /* Check if frequency is configured */
+ if (priv->freq != 1)
+ REG_WRITE(&priv->regs->conf[0], conf0 | CONF0_TE);
+int spwtdp_target_enable(void *spwtdp)
+ /* Check priv */
+ if (priv == NULL)
+ REG_WRITE(&priv->regs->conf[0], conf0 | CONF0_RE);
+int spwtdp_initiator_disable(void *spwtdp)
+ /* Check priv */
+ if (priv == NULL)
+ REG_WRITE(&priv->regs->conf[0], conf0 & ~(CONF0_TE));
+int spwtdp_target_disable(void *spwtdp)
+ /* Check priv */
+ if (priv == NULL)
+ REG_WRITE(&priv->regs->conf[0], conf0 & ~(CONF0_RE));
+/* Get and Clear status */
+int spwtdp_status(void *spwtdp, uint32_t *sts, uint32_t clrmask)
+ /* SPWTDP not initialized */
+ unsigned int status = REG_READ(&priv->regs->stat[0]);
+ REG_WRITE(&priv->regs->stat[0], status & clrmask);
+ if (sts != NULL)
+ *sts = status;
+/* Get and Clear interrupts */
+int spwtdp_interrupt_status(void *spwtdp, uint32_t *sts, uint32_t clrmask)
+ unsigned int status = REG_READ(&priv->regs->ists);
+ REG_WRITE(&priv->regs->ists, status & clrmask);
+ if (sts != NULL)
+ *sts = status;
+/* Unmask interrupts */
+int spwtdp_interrupt_unmask(void *spwtdp, uint32_t irqmask)
+ unsigned int ctrl = REG_READ(&priv->regs->ien);
+ REG_WRITE(&priv->regs->ien, ctrl | irqmask);
+/* Mask interrupts */
+int spwtdp_interrupt_mask(void *spwtdp, uint32_t irqmask)
+ REG_WRITE(&priv->regs->ien, ctrl & ~(irqmask));
+int spwtdp_isr_register(void *spwtdp, spwtdp_isr_t func, void *data)
+ SPIN_ISR_IRQFLAGS(irqflags);
+ /* Check isr */
+ if (func == NULL) {
+ /* No ISR */
+ priv->isr = func;
+ priv->isr_arg = data;
+ /* Register and Enable Interrupt at Interrupt controller */
+ drvmgr_interrupt_register(priv->dev, 0, "spwtdp", spwtdp_isr, priv);
+ /* Enable AMBA Interrupts */
+ SPIN_LOCK(&priv->devlock, irqflags);
+ unsigned int cfg0 = REG_READ(&priv->regs->conf[0]);
+ REG_WRITE(&priv->regs->conf[0], cfg0 | CONF0_AE);
+ SPIN_UNLOCK(&priv->devlock, irqflags);
+int spwtdp_isr_unregister(void *spwtdp)
+ /* Disable IRQS (and check for priv!=NULL) */
+ int ret=spwtdp_interrupt_mask(spwtdp, SPWTDP_IRQ_WCLEAR);
+ return ret;
+ /* Disable AMBA Interrupts */
+ REG_WRITE(&priv->regs->conf[0], cfg0 & ~(CONF0_AE));
+ /* Disable Interrupt at Interrupt controller */
+ drvmgr_interrupt_unregister(priv->dev, 0, spwtdp_isr, priv);
+ /* Unregister isr */
+ priv->isr = NULL;
+ priv->isr_arg = NULL;
+STATIC void spwtdp_isr(void *arg)
+ struct spwtdp_priv *priv = arg;
+ unsigned int ists = REG_READ(&priv->regs->ists);
+ /* Return if the SPWTDP didn't generate the IRQ */
+ if (ists == 0)
+ return;
+ REG_WRITE(&priv->regs->ists, ists); /* clear handled interrupt events */
+ /* Let user Handle Interrupt */
+ if (priv->isr!=NULL)
+ priv->isr(ists, priv->isr_arg);
+ return;
+int spwtdp_dat_et_get(void * spwtdp, spwtdp_time_t * val)
+ /* Check pointer */
+ if (val == NULL) {
+ val->preamble = REG_READ(&priv->regs->dat_ctrl) & ETCTRL_PF;
+ unsigned int * buffer = (unsigned int *) val->data;
+ buffer[0] = REG_READ(&priv->regs->dat_et[0]);
+ buffer[1] = REG_READ(&priv->regs->dat_et[1]);
+ buffer[2] = REG_READ(&priv->regs->dat_et[2]);
+ buffer[3] = REG_READ(&priv->regs->dat_et[3]);
+ buffer[4] = REG_READ(&priv->regs->dat_et[4]);
+int spwtdp_tsrx_et_get(void * spwtdp, spwtdp_time_t * val)
+ val->preamble = REG_READ(&priv->regs->ts_rx_ctrl) & ETCTRL_PF;
+ buffer[0] = REG_READ(&priv->regs->ts_rx_et[0]);
+ buffer[1] = REG_READ(&priv->regs->ts_rx_et[1]);
+ buffer[2] = REG_READ(&priv->regs->ts_rx_et[2]);
+ buffer[3] = REG_READ(&priv->regs->ts_rx_et[3]);
+ buffer[4] = REG_READ(&priv->regs->ts_rx_et[4]);
+int spwtdp_tstx_et_get(void * spwtdp, spwtdp_time_t * val)
+ val->preamble = REG_READ(&priv->regs->ts_tx_ctrl) & ETCTRL_PF;
+ buffer[0] = REG_READ(&priv->regs->ts_tx_et[0]);
+ buffer[1] = REG_READ(&priv->regs->ts_tx_et[1]);
+ buffer[2] = REG_READ(&priv->regs->ts_tx_et[2]);
+ buffer[3] = REG_READ(&priv->regs->ts_tx_et[3]);
+ buffer[4] = REG_READ(&priv->regs->ts_tx_et[4]);
+int spwtdp_lat_et_get(void * spwtdp, spwtdp_time_t * val)
+ val->preamble = REG_READ(&priv->regs->lat_ctrl) & ETCTRL_PF;
+ buffer[0] = REG_READ(&priv->regs->lat_et[0]);
+ buffer[1] = REG_READ(&priv->regs->lat_et[1]);
+ buffer[2] = REG_READ(&priv->regs->lat_et[2]);
+ buffer[3] = REG_READ(&priv->regs->lat_et[3]);
+ buffer[4] = REG_READ(&priv->regs->lat_et[4]);
+int spwtdp_cmd_et_get(void * spwtdp, spwtdp_time_t * val)
+ val->preamble = REG_READ(&priv->regs->cmd_ctrl) & ETCTRL_PF;
+ buffer[0] = REG_READ(&priv->regs->cmd_et[0]);
+ buffer[1] = REG_READ(&priv->regs->cmd_et[1]);
+ buffer[2] = REG_READ(&priv->regs->cmd_et[2]);
+ buffer[3] = REG_READ(&priv->regs->cmd_et[3]);
+ buffer[4] = REG_READ(&priv->regs->cmd_et[4]);
+int spwtdp_initiator_tstx_conf(void * spwtdp, uint8_t tstc)
+ REG_WRITE(&priv->regs->ts_tx_ctrl,
+ (((uint32_t)tstc) << TSTXCTRL_TSTC_BIT) & TSTXCTRL_TSTC);
+int spwtdp_initiator_cmd_et_set(void *spwtdp, spwtdp_time_t val)
+ unsigned int * buffer = (unsigned int *) val.data;
+ REG_WRITE(&priv->regs->lat_et[0], buffer[0]);
+ REG_WRITE(&priv->regs->lat_et[1], buffer[1]);
+ REG_WRITE(&priv->regs->lat_et[2], buffer[2]);
+ REG_WRITE(&priv->regs->lat_et[3], buffer[3]);
+ REG_WRITE(&priv->regs->lat_et[4], buffer[4]);
+ /* Signal new command */
+ unsigned int ctrl = REG_READ(&priv->regs->cmd_ctrl);
+ REG_WRITE(&priv->regs->cmd_ctrl, ctrl | CTRL_NC);
+int spwtdp_initiator_cmd_spwtc_set(void *spwtdp, uint8_t spwtc)
+ unsigned int ctrl = (REG_READ(&priv->regs->cmd_ctrl) &~ CTRL_SPWTC);
+ ctrl | (((uint32_t)spwtc << CTRL_SPWTC_BIT) & CTRL_SPWTC));
+#define CTRL_TAR_MASK (CTRL_NC|CTRL_IS)
+int spwtdp_target_cmd_conf(void *spwtdp, uint8_t spwtc, uint16_t cpf,
+ uint32_t options)
+ (options & CTRL_TAR_MASK) |
+ ((cpf << CTRL_CPF_BIT) & CTRL_CPF) |
+ (((uint32_t)spwtc << CTRL_SPWTC_BIT) & CTRL_SPWTC));
+int spwtdp_precision_get(void *spwtdp, uint8_t *fine, uint8_t *coarse)
+ int coarse_precision, fine_precision;
+ unsigned int preamble = REG_READ(&priv->regs->dat_ctrl);
+ if (preamble & 0x80) {
+ DBG("Pfield second extension set: unknown format");
+ if (!((preamble & 0x7000) == 0x2000 || (preamble & 0x7000) == 0x1000)) {
+ DBG(" PField indicates not unsegmented code: unknown format");
+ * coarse_precision = 32;
+ * fine_precision = 24;
+ coarse_precision = ((preamble >> 10) & 0x3) + 1;
+ coarse_precision += (preamble >> 5) & 0x3;
+ fine_precision = (preamble >> 8) & 0x3;
+ fine_precision += (preamble >> 2) & 0x7;
+ if (coarse!=NULL)
+ *coarse = coarse_precision;
+ if (fine!=NULL)
+ *fine = fine_precision;
diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
index cd36515..aaaa484 100644
--- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
@@ -143,9 +143,13 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/sparc/shared/tmtc/grtm.c
# MEMSCRUB
librtemsbsp_a_SOURCES += ../../../../../../bsps/sparc/shared/scrub/memscrub.c
# L4STAT
librtemsbsp_a_SOURCES += ../../../../../../bsps/sparc/shared/stat/l4stat.c
+# SPWTDP
+librtemsbsp_a_SOURCES += ../../../../../../bsps/sparc/shared/spw/spwtdp.c
# Driver Manager
librtemsbsp_a_SOURCES += ../../../../../../bsps/sparc/shared/drvmgr/ambapp_bus.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/sparc/shared/drvmgr/ambapp_bus_leon2.c
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index 9d7d59d..4cd2652 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -162,8 +162,13 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/sparc/shared/tmtc/grtm.c
# MEMSCRUB
# L4STAT
+# SPWTDP
# Driver Manager
librtemsbsp_a_SOURCES += ../../../../../../bsps/sparc/shared/drvmgr/ambapp_bus_grlib.c
diff --git a/cpukit/include/drvmgr/drvmgr_confdefs.h b/cpukit/include/drvmgr/drvmgr_confdefs.h
index 82829bd..a1c6bd6 100644
--- a/cpukit/include/drvmgr/drvmgr_confdefs.h
+++ b/cpukit/include/drvmgr/drvmgr_confdefs.h
@@ -61,6 +61,7 @@ extern void router_register_drv(void);
extern void ahbstat_register_drv(void);
extern void memscrub_register_drv(void);
extern void l4stat_register_drv(void);
+extern void spwtdp_register_drv(void);
/*** LEON2 AMBA Hard coded bus Drivers ***/
@@ -178,6 +179,9 @@ drvmgr_drv_reg_func drvmgr_drivers[] = {
#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_L4STAT
l4stat_register_drv,
#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_SPWTDP
+ spwtdp_register_drv,
+#endif
/*** LEON2 AMBA Drivers ***/
#ifdef CONFIGURE_DRIVER_LEON2_AT697PCI
2.7.4
