RTEMS build broken on msys2
Thu Oct 11 13:16:31 UTC 2018
Hello,
it is always a pleasure to work on Windows via msys2. After my recent
Makefile.am changes the argument list to create the library is too long:
in_cpuinfo.o libmisc/shell/main_profreport.o libmisc/utf8proc/utf8proc.o
libmd/sha256c.o libmd/sha512c.o             score/cpu/no_cpu/cpuidle.o
score/cpu/powerpc/cpu.o score/cpu/powerpc/ppc-context-volatile-clobber.o
score/cpu/powerpc/ppc-context-validate.o
score/cpu/powerpc/ppc-isr-disable-mask.o
score/cpu/powerpc/ppc-isr-vector-install.o
make[4]: execvp: powerpc-rtems5-ar: Argument list too long
Some time ago we had the same problem with libbsd and got a fix for waf
due to that. What works is this manual hack:
librtemscpu.a: $(librtemscpu_a_OBJECTS) $(librtemscpu_a_DEPENDENCIES)
$(EXTRA_librtemscpu_a_DEPENDENCIES)
         -rm -f librtemscpu.a
         echo "" > librtemscpu.txt
         for i in $(librtemscpu_a_OBJECTS) ; do $$i >>librtemscpu.txt ; done
         $(librtemscpu_a_AR) librtemscpu.a @librtemscpu.txt
$(librtemscpu_a_LIBADD)
         $(RANLIB) librtemscpu.a
The standard Automake target is this:
     $(librtemscpu_a_AR) librtemscpu.a $(librtemscpu_a_OBJECTS)
Is it possible to override a Automake generated target with a custom
variant?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
