RTEMS build broken on msys2
Joel Sherrill
joel at rtems.org
Thu Oct 11 13:59:32 UTC 2018
On Thu, Oct 11, 2018, 6:16 AM Sebastian Huber <
> Hello,
> it is always a pleasure to work on Windows via msys2. After my recent
> Makefile.am changes the argument list to create the library is too long:
> in_cpuinfo.o libmisc/shell/main_profreport.o libmisc/utf8proc/utf8proc.o
> libmd/sha256c.o libmd/sha512c.o score/cpu/no_cpu/cpuidle.o
> score/cpu/powerpc/cpu.o score/cpu/powerpc/ppc-context-volatile-clobber.o
> score/cpu/powerpc/ppc-context-validate.o
> score/cpu/powerpc/ppc-isr-disable-mask.o
> score/cpu/powerpc/ppc-isr-vector-install.o
> make[4]: execvp: powerpc-rtems5-ar: Argument list too long
Since we would like to eventually move the legacy Network stack to another
package entirely, would simply letting it and pppd be their in Makefile,am
and separate library installed help.
Eventually we may hit the limit again but we may be at waf by then.
> Some time ago we had the same problem with libbsd and got a fix for waf
> due to that. What works is this manual hack:
> librtemscpu.a: $(librtemscpu_a_OBJECTS) $(librtemscpu_a_DEPENDENCIES)
> $(EXTRA_librtemscpu_a_DEPENDENCIES)
> -rm -f librtemscpu.a
> echo "" > librtemscpu.txt
> for i in $(librtemscpu_a_OBJECTS) ; do $$i >>librtemscpu.txt ;
> done
> $(librtemscpu_a_AR) librtemscpu.a @librtemscpu.txt
> $(librtemscpu_a_LIBADD)
> $(RANLIB) librtemscpu.a
> The standard Automake target is this:
> $(librtemscpu_a_AR) librtemscpu.a $(librtemscpu_a_OBJECTS)
> Is it possible to override a Automake generated target with a custom
> variant?
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181011/69c22da6/attachment-0002.html>
