[PATCH] Covoar : remove lib parsing as the support is shifted to coverage script
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Tue Oct 16 06:00:38 UTC 2018
On Tue, Oct 16, 2018, 11:24 AM Chris Johns <chrisj at rtems.org> wrote:
> On 16/10/2018 14:37, Vijay Kumar Banerjee wrote:
> > tester/covoar/DesiredSymbols.cc | 16 +++++++---------
> > 1 file changed, 7 insertions(+), 9 deletions(-)
> > diff --git a/tester/covoar/DesiredSymbols.cc
> b/tester/covoar/DesiredSymbols.cc
> > index 60d22c3..94ab562 100644
> > --- a/tester/covoar/DesiredSymbols.cc
> > +++ b/tester/covoar/DesiredSymbols.cc
> > @@ -55,10 +55,10 @@ namespace Coverage {
> > // For each set read the libraries from the configuration file and
> load.
> > // [A]
> > - // libraries = @BUILD-PREFIX@/c/@BSP@/A/libA.a
> > + // libraries = @BUILD-PREFIX@/c/@BSP@/A
> > // [B]
> > - // libraries = @BUILD-PREFIX@/c/@BSP@/B/libB.a
> > + // libraries = @BUILD-PREFIX@/c/@BSP@/B
> > try {
> > cache.open();
> > @@ -79,14 +79,12 @@ namespace Coverage {
> > if (verbose)
> > std::cerr << " Symbol set: " << set << std::endl;
> > const rld::config::section& set_section =
> config.get_section(set);
> > - rld::strings libs;
> > - rld::config::parse_items (set_section, "libraries", libs, true);
> > - for (std::string lib : libs) {
> > - lib = rld::find_replace(lib, "@BUILD-TARGET@", buildTarget);
> > - lib = rld::find_replace(lib, "@BSP@", buildBSP);
> > + rld::strings objs;
> > + rld::config::parse_items (set_section, "libraries", objs, true);
> > + for (std::string obj : objs) {
> > if (verbose)
> > - std::cerr << " Loading library: " << lib << std::endl;
> > - cache.add(lib);
> > + std::cerr << " Loading Object: " << obj << std::endl;
> > + cache.add(obj);
> I must be missing how the path in the INI file is transformed into a
> container
> of '.o' files?
this is done by the script, here it just parses the container
> I suspect we may need a C++ version of the path.py's 'listdir' that
> accepts a
> regrex and returns a 'paths' container.
The ini file with the object files are being fed to covoar by the script
Are we looking to have the parsing support shifted to covoar?
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181016/7b50deda/attachment.html>
