[PATCH v2] sb: Add support to search for a suitable version of python.
Wed Oct 24 08:33:37 UTC 2018
> On 24 Oct 2018, at 6:29 pm, Malte Münch <mamu at stablerock.de> wrote:
> Hi Chris,
> thanks for your answer. I said yesterday: "it worked fine before commit
> 13f4c379997b53b204d8534d198da2fa35dd5630" that was actually not true.
> The first part worked fine but lateron the GDB build failed. I solved
> that issue by reverting even further back.
> Your patch works well for the first part:
Great, I will push it. Thank you for testing and reporting back.
> [mamu at verstappen rtems]$ ../source-builder/sb-set-builder
> --prefix=/home/mamu/vcs/git/development/rtems/5 --dry-run --trace
> 5/rtems-sparc
> RTEMS Source Builder - Set Builder, 5 (1e9075af6803 modified)
> Build Set: 5/rtems-sparc
> Build Set: 5/rtems-autotools.bset
> Build Set: 5/rtems-autotools-internal.bset
> config: tools/rtems-autoconf-2.69-1.cfg
> package: autoconf-2.69-x86_64-linux-gnu-1
>  See error report: rsb-report-autoconf-2.69-x86_64-linux-gnu-1.txt
> config: tools/rtems-automake-1.12.6-1.cfg
> package: automake-1.12.6-x86_64-linux-gnu-1
>  See error report: rsb-report-automake-1.12.6-x86_64-linux-gnu-1.txt
> cleaning: autoconf-2.69-x86_64-linux-gnu-1
> cleaning: automake-1.12.6-x86_64-linux-gnu-1
> Build Sizes: usage: 0.000B total: 135.959MB (sources: 135.710MB,
> patches: 254.826KB, installed 0.000B)
> Build Set: Time 0:00:02.362507
> Build Set: 5/rtems-autotools-base.bset
> reporting: tools/rtems-autoconf-2.69-1.cfg ->
> autoconf-2.69-x86_64-linux-gnu-1.xml
> reporting: tools/rtems-automake-1.12.6-1.cfg ->
> automake-1.12.6-x86_64-linux-gnu-1.xml
> installing: autoconf-2.69-x86_64-linux-gnu-1 ->
> installing: automake-1.12.6-x86_64-linux-gnu-1 ->
> Build Set: Time 0:00:06.290691
> Build Set: Time 0:00:08.658924
> config: devel/expat-2.1.0-1.cfg
> package: expat-2.1.0-x86_64-linux-gnu-1
>  See error report: rsb-report-expat-2.1.0-x86_64-linux-gnu-1.txt
> reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.txt
> reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.xml
> config: tools/rtems-gdb-8.0.1-1.cfg
> error: config error: gdb-common-1.cfg:87: "gdb: python: header file not
> found: python2.7/Python.h, please install"
> Build FAILED
> Build Set: Time 0:00:09.203917
> Build FAILED
At the end of the log is the shell command used to find the header. Could you please run that command in a shell and if you add ‘-d’ the shell will trace itself.
Also do you know where ArchLinux puts the python header?
>> Is this link from a package or something you have done?
> I asked me that as well, i knew this question would come :D
It is any interesting issue that now exists.
> I don't know
> but i think this is standard. The Archlinux-Wiki says:
> Any program requiring Python 2 needs to point to /usr/bin/python2,
> instead of /usr/bin/python, which points to Python 3.
This makes sense to me but not all distributions see this the same way.
