[PATCH v2] sb: Add support to search for a suitable version of python.
Malte Münch mamu at stablerock.de
Wed Oct 24 08:43:56 UTC 2018
Hi,
i think you meant that command here:
/home/mamu/dr/rsb/source-builder/sb/rtems-build-dep -c gcc  -H
python2.7/Python.h
with an additional -d flag it returns:
+ '[' -z header ']'
+ '[' -z gcc ']'
+ '[' -z python2.7/Python.h ']'
+ '[' header = header ']'
++ echo
++ gcc -xc -E -v -
++ awk 'BEGIN {flag=0;} /starts here/{flag=1;next}/End/{flag=0}flag'
+ inc_paths=
+ echo not-found
not-found
+ exit 0
The python header is located under /usr/include:
[mamu at verstappen rtems]$ find / -name 'Python.h' 2> /dev/null
/usr/include/python2.7/Python.h
/usr/include/python3.7m/Python.h
Best,
Malte
On 10/24/18 10:33 AM, Chris Johns wrote:
>> On 24 Oct 2018, at 6:29 pm, Malte Münch <mamu at stablerock.de> wrote:
>> Hi Chris,
>> thanks for your answer. I said yesterday: "it worked fine before commit
>> 13f4c379997b53b204d8534d198da2fa35dd5630" that was actually not true.
>> The first part worked fine but lateron the GDB build failed. I solved
>> that issue by reverting even further back.
>> Your patch works well for the first part:
> Great, I will push it. Thank you for testing and reporting back.
>> [mamu at verstappen rtems]$ ../source-builder/sb-set-builder
>> --prefix=/home/mamu/vcs/git/development/rtems/5 --dry-run --trace
>> 5/rtems-sparc
>> RTEMS Source Builder - Set Builder, 5 (1e9075af6803 modified)
>> Build Set: 5/rtems-sparc
>> Build Set: 5/rtems-autotools.bset
>> Build Set: 5/rtems-autotools-internal.bset
>> config: tools/rtems-autoconf-2.69-1.cfg
>> package: autoconf-2.69-x86_64-linux-gnu-1
>>  See error report: rsb-report-autoconf-2.69-x86_64-linux-gnu-1.txt
>> config: tools/rtems-automake-1.12.6-1.cfg
>> package: automake-1.12.6-x86_64-linux-gnu-1
>>  See error report: rsb-report-automake-1.12.6-x86_64-linux-gnu-1.txt
>> cleaning: autoconf-2.69-x86_64-linux-gnu-1
>> cleaning: automake-1.12.6-x86_64-linux-gnu-1
>> Build Sizes: usage: 0.000B total: 135.959MB (sources: 135.710MB,
>> patches: 254.826KB, installed 0.000B)
>> Build Set: Time 0:00:02.362507
>> Build Set: 5/rtems-autotools-base.bset
>> reporting: tools/rtems-autoconf-2.69-1.cfg ->
>> autoconf-2.69-x86_64-linux-gnu-1.xml
>> reporting: tools/rtems-automake-1.12.6-1.cfg ->
>> automake-1.12.6-x86_64-linux-gnu-1.xml
>> installing: autoconf-2.69-x86_64-linux-gnu-1 ->
>> installing: automake-1.12.6-x86_64-linux-gnu-1 ->
>> Build Set: Time 0:00:06.290691
>> Build Set: Time 0:00:08.658924
>> config: devel/expat-2.1.0-1.cfg
>> package: expat-2.1.0-x86_64-linux-gnu-1
>>  See error report: rsb-report-expat-2.1.0-x86_64-linux-gnu-1.txt
>> reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.txt
>> reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.xml
>> config: tools/rtems-gdb-8.0.1-1.cfg
>> error: config error: gdb-common-1.cfg:87: "gdb: python: header file not
>> found: python2.7/Python.h, please install"
>> Build FAILED
>> Build Set: Time 0:00:09.203917
>> Build FAILED
> At the end of the log is the shell command used to find the header. Could you please run that command in a shell and if you add ‘-d’ the shell will trace itself.
> Also do you know where ArchLinux puts the python header?
>>> Is this link from a package or something you have done?
>> I asked me that as well, i knew this question would come :D
> It is any interesting issue that now exists.
>> I don't know
>> but i think this is standard. The Archlinux-Wiki says:
>> Any program requiring Python 2 needs to point to /usr/bin/python2,
>> instead of /usr/bin/python, which points to Python 3.
> This makes sense to me but not all distributions see this the same way.
> Chris
