[PATCH] Coverage: add the style and js files to the symbol-set report directory
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sun Oct 28 09:33:59 UTC 2018
On Sun, 28 Oct 2018 at 09:00, Chris Johns <chrisj at rtems.org> wrote:
> On 27/10/18 5:13 am, Vijay Kumar Banerjee wrote:
> > tester/rt/coverage.py | 17 ++++-------------
> > 1 file changed, 4 insertions(+), 13 deletions(-)
> > diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
> > index 978a8c4..4200dad 100644
> > --- a/tester/rt/coverage.py
> > +++ b/tester/rt/coverage.py
> > @@ -201,23 +201,14 @@ class report_gen_html:
> > index_content = self._prepare_index_content(partial_reports)
> > self._create_index_file(head_section,index_content)
> > - def add_covoar_src_path(self):
> > + def add_covoar_css(self):
> > table_js_path = path.join(self.covoar_src_path, 'table.js')
> > covoar_css_path = path.join(self.covoar_src_path, 'covoar.css')
> > for symbol_set in self.symbol_sets:
> > symbol_set_dir = path.join(self.build_dir,
> > self.bsp + '-coverage',
> symbol_set)
> > - html_files = os.listdir(symbol_set_dir)
> > - for html_file in html_files:
> > - html_file = path.join(symbol_set_dir, html_file)
> > - if path.exists(html_file) and 'html' in html_file:
> > - with open(html_file, 'r') as f:
> > - file_data = f.read()
> > - file_data = file_data.replace('table.js',
> table_js_path)
> > - file_data = file_data.replace('covoar.css',
> > - covoar_css_path)
> > - with open(html_file, 'w') as f:
> > - f.write(file_data)
> > + shutil.copy(covoar_css_path, symbol_set_dir)
> > + shutil.copy(table_js_path, symbol_set_dir)
> How portable are these calls?
> Please have a look at 'path.copy_tree' in the rtemstoolkit's path.py. I
> think you can use that call instead.
> shutil is portable as it comes with python. i looked into the
path.copy_tree
it uses shutil as well, but it requires the source-name to be a directory
wherefrom it will copy all the files to destination directory.
Is there a reason that path.copy_tree has been used instead of
shutil.copytree ?
https://docs.python.org/2/library/shutil.html#shutil.copytree
> > class build_path_generator(object):
> > @@ -402,7 +393,7 @@ class coverage_run(object):
> > self.rtdir,
> > self.macros['bsp'])
> > report.generate()
> > - report.add_covoar_src_path()
> > + report.add_covoar_css()
> > def _cleanup(self):
> > if not self.no_clean:
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181028/815edb15/attachment.html>
