[PATCH] Coverage: add the style and js files to the symbol-set report directory
Sun Oct 28 10:15:56 UTC 2018
On 28/10/18 8:33 pm, Vijay Kumar Banerjee wrote:
> On Sun, 28 Oct 2018 at 09:00, Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     On 27/10/18 5:13 am, Vijay Kumar Banerjee wrote:
>      >   tester/rt/coverage.py | 17 ++++-------------
>      >   1 file changed, 4 insertions(+), 13 deletions(-)
>      > diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>      > index 978a8c4..4200dad 100644
>      > --- a/tester/rt/coverage.py
>      > +++ b/tester/rt/coverage.py
>      > @@ -201,23 +201,14 @@ class report_gen_html:
>      >           index_content =
>     self._prepare_index_content(partial_reports)
>      >           self._create_index_file(head_section,index_content)
>      > -    def add_covoar_src_path(self):
>      > +    def add_covoar_css(self):
>      >           table_js_path = path.join(self.covoar_src_path, 'table.js')
>      >           covoar_css_path = path.join(self.covoar_src_path,
>     'covoar.css')
>      >           for symbol_set in self.symbol_sets:
>      >               symbol_set_dir = path.join(self.build_dir,
>      >                                          self.bsp + '-coverage',
>     symbol_set)
>      > -            html_files = os.listdir(symbol_set_dir)
>      > -            for html_file in html_files:
>      > -                html_file = path.join(symbol_set_dir, html_file)
>      > -                if path.exists(html_file) and 'html' in html_file:
>      > -                    with open(html_file, 'r') as f:
>      > -                        file_data = f.read()
>      > -                    file_data = file_data.replace('table.js',
>     table_js_path)
>      > -                    file_data = file_data.replace('covoar.css',
>      > -                                                  covoar_css_path)
>      > -                    with open(html_file, 'w') as f:
>      > -                        f.write(file_data)
>      > +            shutil.copy(covoar_css_path, symbol_set_dir)
>      > +            shutil.copy(table_js_path, symbol_set_dir)
>     How portable are these calls?
>     Please have a look at 'path.copy_tree' in the rtemstoolkit's path.py. I
>     think you can use that call instead.
> shutil is portable as it comes with python.
It does not handle some issues on Windows.
> i looked into the path.copy_tree
> it uses shutil as well,
It does but it handles some issues expose in the RSB over many years.
> but it requires the source-name to be a directory
> wherefrom it will copy all the files to destination directory.
It can be extended.
> Is there a reason that path.copy_tree has been used instead of
> shutil.copytree ?
> https://docs.python.org/2/library/shutil.html#shutil.copytree
It can break on Windows.
Please use the path module for all file operations to we can be
portable. I think one call was pushed in the other patch which Joel
merged that needs to be fixed.
