Can't find Python.h on MSYS2 -- It's there
    Chris Johns
    chrisj at rtems.org
    Tue Oct 23 20:34:45 UTC 2018
On 24/10/2018 01:59, Joel Sherrill wrote:
> On Mon, Oct 22, 2018 at 7:03 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     On 23/10/2018 10:44, Joel Sherrill wrote:
>     > On Mon, Oct 22, 2018, 6:37 PM Chris Johns <chrisj at rtems.org
>     > <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>>> wrote:
>     > Hmm ... I installed msys2 from scratch in the last couple of weeks. I used the
>     > Pacman command in the hosts section (formerly in the RSB). Are there two
>     Pacman
>     > command examples?
>     I cannot find any mention after you merged the Quick starts into a single one in
>     the User Manual.
>     > I will scratch my msys2 and try again tomorrow but please check if there
>     are two
>     > separate sections with Pacman command advice.
>     Sure.
> Hmmm... user/hosts/windows.rst and rsb/hosts.rst still have example pacman
> commands. I suspect I should have removed rsb/hosts.rst. :(
Yes, hmmm. Did those sections move over in your merge? I only looked in the RSB
manual.
> Fresh msys2 install:
>  $ pacman -S python mingw-w64-x86_64-python2 mingw-w64-x86_64-gcc \
>   bison cvs diffutils git make patch tar texinfo unzip
> $ git clone git://git.rtems.org/rtems-source-builder.git
> <http://git.rtems.org/rtems-source-builder.git>
> $ cd rtems-source-builder/rtems
> jrs007 at JRS-OAR-Laptop MSYS ~/rtems-source-builder/rtems
> $ ../source-builder/sb-check
> error: no hosts defaults found; please add
> $ ../source-builder/sb-set-builder --source-only-download 5/rtems-sparc
> Build FAILED
> Seems like something got worse.
What do ...
 $ python ../source-builder/sb/windows.py
 $ set | grep PATH
... show?
