[PATCH] Coverage : Use '.o' files for coverage analysis
Thu Oct 25 19:26:00 UTC 2018
Vijay,
Did covoar just work after adjusting the files to be .o's? Or are there
more changes?
If not, I just need the current patch with a good log message.
--joel
On Thu, Oct 25, 2018 at 2:06 PM Vijay Kumar Banerjee <
vijaykumar9597 at gmail.com> wrote:
> Hi Chris!
> Do you find the patch alright? I was wondering if you were expecting some
> changes or modifications. I can do it and submit within this week. :)
> On Tue, 16 Oct 2018 at 09:06, Vijay Kumar Banerjee <
>> mistakenly resent this. Sorry about it.
>> I have made a separate patch for covoar,
>> I intended to send that one. :)
>> On Tue, Oct 16, 2018, 9:03 AM Vijay Kumar Banerjee <
>>> Use the Object files in cpukit/ instead of the static library
>>> for Coverage analysis
>>>  tester/rt/coverage.py                         | 27 ++++--
>>>  tester/rtems/testing/coverage/symbol-sets.ini | 90 +++++++++----------
>>>  2 files changed, 66 insertions(+), 51 deletions(-)
>>> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>>> index c979332..55cb59a 100644
>>> --- a/tester/rt/coverage.py
>>> +++ b/tester/rt/coverage.py
>>> @@ -244,13 +244,17 @@ class symbol_parser(object):
>>>                   symbol_config_path,
>>>                   symbol_select_path,
>>>                   symbol_set,
>>> -                 build_dir):
>>> +                 build_dir,
>>> +                 bsp_name,
>>> +                 target):
>>>          self.symbol_select_file = symbol_select_path
>>>          self.symbol_file = symbol_config_path
>>>          self.build_dir = build_dir
>>>          self.symbol_sets = {}
>>>          self.symbol_set = symbol_set
>>>          self.ssets = []
>>> +        self.bsp_name = bsp_name
>>> +        self.target = target
>>>      def parse(self):
>>>          config = configparser.ConfigParser()
>>> @@ -264,9 +268,13 @@ class symbol_parser(object):
>>>              for sset in self.ssets:
>>>                  lib = path.join(self.build_dir, config.get('libraries',
>>> sset))
>>>                  self.symbol_sets[sset] = lib.encode('utf-8')
>>> +                ss = self.symbol_sets[sset]
>>> +                ss = ss.replace('@BSP@', self.bsp_name)
>>> +                ss = ss.replace('@BUILD-TARGET@', self.target)
>>> +                self.symbol_sets[sset] = ss
>>>              return self.ssets
>>>          except:
>>> -            raise error.general('Symbol set parsing failed')
>>> +            raise error.general('Symbol set parsing failed for %s' %
>>> sset)
>>>      def write_ini(self, symbol_set):
>>> @@ -275,11 +283,15 @@ class symbol_parser(object):
>>>              config.add_section('symbol-sets')
>>>              config.set('symbol-sets', 'sets', sset)
>>>              config.add_section(sset)
>>> -            config.set(sset, 'libraries', self.symbol_sets[sset])
>>> +            object_files = [o for o in
>>> os.listdir(self.symbol_sets[sset]) if o[-1] == 'o']
>>> +            object_paths = []
>>> +            for o in object_files:
>>> +                object_paths.append(path.join(self.symbol_sets[sset],
>>> o))
>>> +            config.set(sset, 'libraries', ','.join(object_paths))
>>>              with open(self.symbol_select_file, 'w') as conf:
>>> -                config.write(conf)
>>> +                    config.write(conf)
>>>          except:
>>> -            raise error.general('symbol parser write failed')
>>> +            raise error.general('symbol parser write failed for %s' %
>>> sset)
>>>  class covoar(object):
>>> @@ -357,6 +369,7 @@ class coverage_run(object):
>>>          self.report_format = self.macros['cov_report_format']
>>>          self.target = self.macros['target']
>>> +        self.bsp_name = self.macros['bsp'].split('-')[0]
>>>      def run(self):
>>>          try:
>>> @@ -366,7 +379,9 @@ class coverage_run(object):
>>>              parser = symbol_parser(self.symbol_config_path,
>>>                                     self.symbol_select_path,
>>>                                     self.symbol_set,
>>> -                                   build_dir)
>>> +                                   build_dir,
>>> +                                   self.bsp_name,
>>> +                                   self.target)
>>>              symbol_sets = parser.parse()
>>>              for sset in symbol_sets:
>>>                  parser.write_ini(sset)
>>> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>>> b/tester/rtems/testing/coverage/symbol-sets.ini
>>> index 2685ef4..8f85533 100644
>>> --- a/tester/rtems/testing/coverage/symbol-sets.ini
>>> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>>> @@ -29,50 +29,50 @@
>>>  [symbol-sets]
>>> -sets =
>>> score,rtems,sapi,libdl,posix,libirfs,libdosfs,libdevfs,libimfs,libcsupport,libbspcmdline,libcpuuse,libstackchk,libfsmount,libstringto,libdevnull,libdumpbuf,libblock
>>> +sets =
>>> score,rtems,sapi,libdl,posix,librfs,libdosfs,libdevfs,libimfs,libbspcmdline,libcpuuse,libstackchk,libfsmount,libstringto,libdevnull,libdumpbuf,libblock
>>>  [libraries]
>>> -score         = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>>> -rtems         = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>>> -sapi          = @BUILD-TARGET@/c/@BSP@/cpukit/sapi/libsapi.a
>>> -libdl         = @BUILD-TARGET@/c/@BSP@/cpukit/libdl/libdl.a
>>> -posix         = @BUILD-TARGET@/c/@BSP@/cpukit/posix/libposix.a
>>> -libirfs       = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/librfs.a
>>> -libdosfs      = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/libdosfs.a
>>> -libdevfs      = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/libdevfs.a
>>> -libimfs       = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/libimfs.a
>>> -#libdefaultsfs = @BUiLD-TARGET@/c/@BSP@/cpukit/libfs/libdefaultfs.a
>>> -#libjffs2      = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/libjffs2.a
>>> -#dtc           = @BUILD-TARGET@/c/@BSP@/cpukit/libfdt/libfdt.a
>>> -#libdrvmgr     = @BUILD-TARGET@/c/@BSP@/cpukit/libdrvmgr/libdrvmgr.a
>>> -#libi2c        = @BUILD-TARGET@/c/@BSP@/cpukit/libi2c/libi2c.a
>>> -libcsupport   = @BUILD-TARGET@/c/@BSP@/cpukit/libcsupport/libcsupport.a
>>> -libbspcmdline = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libbspcmdline.a
>>> -libcpuuse     = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libcpuuse.a
>>> -libstackchk   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libstackchk.a
>>> -libfsmount    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libfsmount.a
>>> -libstringto   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libstringto.a
>>> -libdevnull    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libdevnull.a
>>> -libdumpbuf    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libdumpbuf.a
>>> -#libcapture    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libcapture.a
>>> -#libdummy      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libdummy.a
>>> -#libmonitor    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libmonitor.a
>>> -#libmouse      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libmouse.a
>>> -#libmw-fb      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libmw-fb.a
>>> -#libredirector = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libredirector.a
>>> -#librtemsfdt   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/librtemsfdt.a
>>> -#libserdbg     = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libserdbg.a
>>> -#libshell      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libshell.a
>>> -#libtestsupport= @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libtestsupport.a
>>> -#libuntar      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libuntar.a
>>> -#libutf8proc   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libutf8proc.a
>>> -#libuuid       = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libuuid.a
>>> -#libxz         = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libxz.a
>>> -libblock      = @BUILD-TARGET@/c/@BSP@/cpukit/libblock/libblock.a
>>> -#libpci        = @BUILD-TARGET@/c/@BSP@/cpukit/libpci/libpci.a
>>> -#librpc        = @BUILD-TARGET@/c/@BSP@/cpukit/librpc/librpc.a
>>> -#libxdr        = @BUILD-TARGET@/c/@BSP@/cpukit/librpc/libxdr.a
>>> -#libcrypt      = @BUILD-TARGET@/c/@BSP@/cpukit/libcrypt/libcrypt.a
>>> -#libmd         = @BUILD-TARGET@/c/@BSP@/cpukit/libmd/libmd.a
>>> -#libstdthreads = @BUILD-TARGET@/c/@BSP@
>>> /cpukit/libstdthreads/libstdthreads.a
>>> -#zlib          = @BUILD-TARGET@/c/@BSP@/cpukit/zlib/libz.a
>>> +score         = @BUILD-TARGET@/c/@BSP@/cpukit/score/src
>>> +rtems         = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/src
>>> +sapi          = @BUILD-TARGET@/c/@BSP@/cpukit/sapi/src
>>> +libdl         = @BUILD-TARGET@/c/@BSP@/cpukit/libdl
>>> +posix         = @BUILD-TARGET@/c/@BSP@/cpukit/posix/src
>>> +librfs       = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/rfs
>>> +libdosfs      = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/dosfs
>>> +libdevfs      = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/devfs
>>> +libimfs       = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/imfs
>>> +#libdefaultsfs = @BUiLD-TARGET@/c/@BSP@/cpukit/libfs
>>> +#libjffs2      = @BUILD-TARGET@/c/@BSP@/cpukit/libfs
>>> +#dtc           = @BUILD-TARGET@/c/@BSP@/cpukit/libfdt
>>> +#libdrvmgr     = @BUILD-TARGET@/c/@BSP@/cpukit/libdrvmgr
>>> +#libi2c        = @BUILD-TARGET@/c/@BSP@/cpukit/libi2c
>>> +#libcsupport   = @BUILD-TARGET@/c/@BSP@/cpukit/libcsupport/src
>>> +libbspcmdline = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/bspcmdline
>>> +libcpuuse     = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/cpuuse
>>> +libstackchk   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/stackchk
>>> +libfsmount    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/fsmount
>>> +libstringto   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/stringto
>>> +libdevnull    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/devnull
>>> +libdumpbuf    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/dumpbuf
>>> +#libcapture    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>> +#libdummy      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>> +#libmonitor    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>> +#libmouse      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>> +#libmw-fb      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>> +#libredirector = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>> +#librtemsfdt   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>> +#libserdbg     = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>> +#libshell      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>> +#libtestsupport= @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>> +#libuntar      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>> +#libutf8proc   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>> +#libuuid       = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>> +#libxz         = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>> +libblock      = @BUILD-TARGET@/c/@BSP@/cpukit/libblock/src
>>> +#libpci        = @BUILD-TARGET@/c/@BSP@/cpukit/libpci
>>> +#librpc        = @BUILD-TARGET@/c/@BSP@/cpukit/librpc
>>> +#libxdr        = @BUILD-TARGET@/c/@BSP@/cpukit/librpc
>>> +#libcrypt      = @BUILD-TARGET@/c/@BSP@/cpukit/libcrypt
>>> +#libmd         = @BUILD-TARGET@/c/@BSP@/cpukit/libmd
>>> +#libstdthreads = @BUILD-TARGET@/c/@BSP@/cpukit/libstdthreads
>>> +#zlib          = @BUILD-TARGET@/c/@BSP@/cpukit/zlib
>>> 2.17.0
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181025/52eb659c/attachment-0002.html>
