[PATCH] Coverage : Use '.o' files for coverage analysis
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Thu Oct 25 20:18:50 UTC 2018
On Fri, 26 Oct 2018 at 00:56, Joel Sherrill <joel at rtems.org> wrote:
> Vijay,
> Did covoar just work after adjusting the files to be .o's? Or are there
> more changes?
> Covoar just worked after adjusting the files.
> If not, I just need the current patch with a good log message.
> --joel
> On Thu, Oct 25, 2018 at 2:06 PM Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> Hi Chris!
>> Do you find the patch alright? I was wondering if you were expecting some
>> changes or modifications. I can do it and submit within this week. :)
>> On Tue, 16 Oct 2018 at 09:06, Vijay Kumar Banerjee <
>>> mistakenly resent this. Sorry about it.
>>> I have made a separate patch for covoar,
>>> I intended to send that one. :)
>>> On Tue, Oct 16, 2018, 9:03 AM Vijay Kumar Banerjee <
>>>> Use the Object files in cpukit/ instead of the static library
>>>> for Coverage analysis
>>>>  tester/rt/coverage.py                         | 27 ++++--
>>>>  tester/rtems/testing/coverage/symbol-sets.ini | 90 +++++++++----------
>>>>  2 files changed, 66 insertions(+), 51 deletions(-)
>>>> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>>>> index c979332..55cb59a 100644
>>>> --- a/tester/rt/coverage.py
>>>> +++ b/tester/rt/coverage.py
>>>> @@ -244,13 +244,17 @@ class symbol_parser(object):
>>>>                   symbol_config_path,
>>>>                   symbol_select_path,
>>>>                   symbol_set,
>>>> -                 build_dir):
>>>> +                 build_dir,
>>>> +                 bsp_name,
>>>> +                 target):
>>>>          self.symbol_select_file = symbol_select_path
>>>>          self.symbol_file = symbol_config_path
>>>>          self.build_dir = build_dir
>>>>          self.symbol_sets = {}
>>>>          self.symbol_set = symbol_set
>>>>          self.ssets = []
>>>> +        self.bsp_name = bsp_name
>>>> +        self.target = target
>>>>      def parse(self):
>>>>          config = configparser.ConfigParser()
>>>> @@ -264,9 +268,13 @@ class symbol_parser(object):
>>>>              for sset in self.ssets:
>>>>                  lib = path.join(self.build_dir,
>>>> config.get('libraries', sset))
>>>>                  self.symbol_sets[sset] = lib.encode('utf-8')
>>>> +                ss = self.symbol_sets[sset]
>>>> +                ss = ss.replace('@BSP@', self.bsp_name)
>>>> +                ss = ss.replace('@BUILD-TARGET@', self.target)
>>>> +                self.symbol_sets[sset] = ss
>>>>              return self.ssets
>>>>          except:
>>>> -            raise error.general('Symbol set parsing failed')
>>>> +            raise error.general('Symbol set parsing failed for %s' %
>>>> sset)
>>>>      def write_ini(self, symbol_set):
>>>> @@ -275,11 +283,15 @@ class symbol_parser(object):
>>>>              config.add_section('symbol-sets')
>>>>              config.set('symbol-sets', 'sets', sset)
>>>>              config.add_section(sset)
>>>> -            config.set(sset, 'libraries', self.symbol_sets[sset])
>>>> +            object_files = [o for o in
>>>> os.listdir(self.symbol_sets[sset]) if o[-1] == 'o']
>>>> +            object_paths = []
>>>> +            for o in object_files:
>>>> +                object_paths.append(path.join(self.symbol_sets[sset],
>>>> o))
>>>> +            config.set(sset, 'libraries', ','.join(object_paths))
>>>>              with open(self.symbol_select_file, 'w') as conf:
>>>> -                config.write(conf)
>>>> +                    config.write(conf)
>>>>          except:
>>>> -            raise error.general('symbol parser write failed')
>>>> +            raise error.general('symbol parser write failed for %s' %
>>>> sset)
>>>>  class covoar(object):
>>>> @@ -357,6 +369,7 @@ class coverage_run(object):
>>>>          self.report_format = self.macros['cov_report_format']
>>>>          self.target = self.macros['target']
>>>> +        self.bsp_name = self.macros['bsp'].split('-')[0]
>>>>      def run(self):
>>>>          try:
>>>> @@ -366,7 +379,9 @@ class coverage_run(object):
>>>>              parser = symbol_parser(self.symbol_config_path,
>>>>                                     self.symbol_select_path,
>>>>                                     self.symbol_set,
>>>> -                                   build_dir)
>>>> +                                   build_dir,
>>>> +                                   self.bsp_name,
>>>> +                                   self.target)
>>>>              symbol_sets = parser.parse()
>>>>              for sset in symbol_sets:
>>>>                  parser.write_ini(sset)
>>>> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>>>> b/tester/rtems/testing/coverage/symbol-sets.ini
>>>> index 2685ef4..8f85533 100644
>>>> --- a/tester/rtems/testing/coverage/symbol-sets.ini
>>>> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>>>> @@ -29,50 +29,50 @@
>>>>  [symbol-sets]
>>>> -sets =
>>>> score,rtems,sapi,libdl,posix,libirfs,libdosfs,libdevfs,libimfs,libcsupport,libbspcmdline,libcpuuse,libstackchk,libfsmount,libstringto,libdevnull,libdumpbuf,libblock
>>>> +sets =
>>>> score,rtems,sapi,libdl,posix,librfs,libdosfs,libdevfs,libimfs,libbspcmdline,libcpuuse,libstackchk,libfsmount,libstringto,libdevnull,libdumpbuf,libblock
>>>>  [libraries]
>>>> -score         = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>>>> -rtems         = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>>>> -sapi          = @BUILD-TARGET@/c/@BSP@/cpukit/sapi/libsapi.a
>>>> -libdl         = @BUILD-TARGET@/c/@BSP@/cpukit/libdl/libdl.a
>>>> -posix         = @BUILD-TARGET@/c/@BSP@/cpukit/posix/libposix.a
>>>> -libirfs       = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/librfs.a
>>>> -libdosfs      = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/libdosfs.a
>>>> -libdevfs      = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/libdevfs.a
>>>> -libimfs       = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/libimfs.a
>>>> -#libdefaultsfs = @BUiLD-TARGET@/c/@BSP@/cpukit/libfs/libdefaultfs.a
>>>> -#libjffs2      = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/libjffs2.a
>>>> -#dtc           = @BUILD-TARGET@/c/@BSP@/cpukit/libfdt/libfdt.a
>>>> -#libdrvmgr     = @BUILD-TARGET@/c/@BSP@/cpukit/libdrvmgr/libdrvmgr.a
>>>> -#libi2c        = @BUILD-TARGET@/c/@BSP@/cpukit/libi2c/libi2c.a
>>>> -libcsupport   = @BUILD-TARGET@/c/@BSP@
>>>> /cpukit/libcsupport/libcsupport.a
>>>> -libbspcmdline = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libbspcmdline.a
>>>> -libcpuuse     = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libcpuuse.a
>>>> -libstackchk   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libstackchk.a
>>>> -libfsmount    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libfsmount.a
>>>> -libstringto   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libstringto.a
>>>> -libdevnull    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libdevnull.a
>>>> -libdumpbuf    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libdumpbuf.a
>>>> -#libcapture    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libcapture.a
>>>> -#libdummy      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libdummy.a
>>>> -#libmonitor    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libmonitor.a
>>>> -#libmouse      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libmouse.a
>>>> -#libmw-fb      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libmw-fb.a
>>>> -#libredirector = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libredirector.a
>>>> -#librtemsfdt   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/librtemsfdt.a
>>>> -#libserdbg     = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libserdbg.a
>>>> -#libshell      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libshell.a
>>>> -#libtestsupport= @BUILD-TARGET@/c/@BSP@
>>>> /cpukit/libmisc/libtestsupport.a
>>>> -#libuntar      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libuntar.a
>>>> -#libutf8proc   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libutf8proc.a
>>>> -#libuuid       = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libuuid.a
>>>> -#libxz         = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libxz.a
>>>> -libblock      = @BUILD-TARGET@/c/@BSP@/cpukit/libblock/libblock.a
>>>> -#libpci        = @BUILD-TARGET@/c/@BSP@/cpukit/libpci/libpci.a
>>>> -#librpc        = @BUILD-TARGET@/c/@BSP@/cpukit/librpc/librpc.a
>>>> -#libxdr        = @BUILD-TARGET@/c/@BSP@/cpukit/librpc/libxdr.a
>>>> -#libcrypt      = @BUILD-TARGET@/c/@BSP@/cpukit/libcrypt/libcrypt.a
>>>> -#libmd         = @BUILD-TARGET@/c/@BSP@/cpukit/libmd/libmd.a
>>>> -#libstdthreads = @BUILD-TARGET@/c/@BSP@
>>>> /cpukit/libstdthreads/libstdthreads.a
>>>> -#zlib          = @BUILD-TARGET@/c/@BSP@/cpukit/zlib/libz.a
>>>> +score         = @BUILD-TARGET@/c/@BSP@/cpukit/score/src
>>>> +rtems         = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/src
>>>> +sapi          = @BUILD-TARGET@/c/@BSP@/cpukit/sapi/src
>>>> +libdl         = @BUILD-TARGET@/c/@BSP@/cpukit/libdl
>>>> +posix         = @BUILD-TARGET@/c/@BSP@/cpukit/posix/src
>>>> +librfs       = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/rfs
>>>> +libdosfs      = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/dosfs
>>>> +libdevfs      = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/devfs
>>>> +libimfs       = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/imfs
>>>> +#libdefaultsfs = @BUiLD-TARGET@/c/@BSP@/cpukit/libfs
>>>> +#libjffs2      = @BUILD-TARGET@/c/@BSP@/cpukit/libfs
>>>> +#dtc           = @BUILD-TARGET@/c/@BSP@/cpukit/libfdt
>>>> +#libdrvmgr     = @BUILD-TARGET@/c/@BSP@/cpukit/libdrvmgr
>>>> +#libi2c        = @BUILD-TARGET@/c/@BSP@/cpukit/libi2c
>>>> +#libcsupport   = @BUILD-TARGET@/c/@BSP@/cpukit/libcsupport/src
>>>> +libbspcmdline = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/bspcmdline
>>>> +libcpuuse     = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/cpuuse
>>>> +libstackchk   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/stackchk
>>>> +libfsmount    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/fsmount
>>>> +libstringto   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/stringto
>>>> +libdevnull    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/devnull
>>>> +libdumpbuf    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/dumpbuf
>>>> +#libcapture    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>>> +#libdummy      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>>> +#libmonitor    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>>> +#libmouse      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>>> +#libmw-fb      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>>> +#libredirector = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>>> +#librtemsfdt   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>>> +#libserdbg     = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>>> +#libshell      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>>> +#libtestsupport= @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>>> +#libuntar      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>>> +#libutf8proc   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>>> +#libuuid       = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>>> +#libxz         = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
>>>> +libblock      = @BUILD-TARGET@/c/@BSP@/cpukit/libblock/src
>>>> +#libpci        = @BUILD-TARGET@/c/@BSP@/cpukit/libpci
>>>> +#librpc        = @BUILD-TARGET@/c/@BSP@/cpukit/librpc
>>>> +#libxdr        = @BUILD-TARGET@/c/@BSP@/cpukit/librpc
>>>> +#libcrypt      = @BUILD-TARGET@/c/@BSP@/cpukit/libcrypt
>>>> +#libmd         = @BUILD-TARGET@/c/@BSP@/cpukit/libmd
>>>> +#libstdthreads = @BUILD-TARGET@/c/@BSP@/cpukit/libstdthreads
>>>> +#zlib          = @BUILD-TARGET@/c/@BSP@/cpukit/zlib
>>>> 2.17.0
>>>> _______________________________________________
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181026/1a214b2c/attachment-0002.html>
