[PATCH 11/25] Merge sapi/Makefile.am into cpukit/Makefile.am
Tue Sep 25 05:30:37 UTC 2018
On 25/09/2018 00:27, Chris Johns wrote:
>>>> We would have to go from the symbol to the ELF file to the DWARF info of the
>>>> compilation unit.
>>> All info should be directly via the ELF and DWARF format. I do not know if we
>>> need to reference the ELF symbol table or we can just use the DWARF CU data. The
>>> use of objdump should be avoided.
>> I only briefly look into this, but you have to go from the rld::symbols::symbol
>> to the DWARF info somehow if DesiredSymbols.cc:95 is the right spot to add this
>> stuff.
> You could be right. The DWARF info will contain all symbols and more.
> Should these files move to the rtems.git repo?
The *.ini files or which files? I would leave the files where they are
and fix the issues first. Afterwards I would think about moving files
around across repositories.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
