[PATCH 11/25] Merge sapi/Makefile.am into cpukit/Makefile.am
Tue Sep 25 05:58:36 UTC 2018
On 25/09/2018 15:30, Sebastian Huber wrote:
> On 25/09/2018 00:27, Chris Johns wrote:
>>>>> We would have to go from the symbol to the ELF file to the DWARF info of the
>>>>> compilation unit.
>>>> All info should be directly via the ELF and DWARF format. I do not know if we
>>>> need to reference the ELF symbol table or we can just use the DWARF CU data.
>>>> The
>>>> use of objdump should be avoided.
>>> I only briefly look into this, but you have to go from the rld::symbols::symbol
>>> to the DWARF info somehow if DesiredSymbols.cc:95 is the right spot to add this
>>> stuff.
>> You could be right. The DWARF info will contain all symbols and more.
>> Should these files move to the rtems.git repo?
> The *.ini files or which files?
Just the INI files, the files which describe the data.
> I would leave the files where they are and fix
> the issues first. Afterwards I would think about moving files around across
> repositories.
Oh of course, that is fine and it makes sense. I would like to understand the
tasks and agree on them.
