Invalid block size of 512B while setting up RFS on RAMDisk
Udit agarwal dev.madaari at gmail.com
Mon Sep 10 18:24:35 UTC 2018
On Mon, Sep 10, 2018 at 8:19 AM Chris Johns <chrisj at rtems.org> wrote:
> On 10/09/2018 12:30, Udit agarwal wrote:
> > Hi list,
> > While setting up RFS with a block size of 512B on a RAMDisk, I had an
> I/O error
> > while formatting /dev/rda using mkrfs shell command.
> > Same procedure repeated for RFS on sd-card/USB-stick did worked with
> 512B block
> > size.
> > Any advice or a fix?
> > BTW, my ramdisk block size is 512B with block count of 262144. and BSP
> used is
> > BeagleBone Black.
> Are you able to make a small test case?
> Yup, i'll make one to reproduce the error.
> Thanks
> Chris
Regards,
Udit kumar agarwal
http://uditagarwal.in/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180910/185429cd/attachment-0002.html>
