Problem with rtems-libbsd build
Jeff Mayes Jeff.Mayes at OARcorp.com
Fri Sep 28 18:03:02 UTC 2018
Joel's recommendation on the BSP variant.  Just trying to do some plain vanilla testing on powerpc.
Thanks!
-----Original Message-----
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
Sent: Friday, September 28, 2018 11:10 AM
To: Jeff Mayes <Jeff.Mayes at OARcorp.com>
Cc: devel <devel at rtems.org>
Subject: Re: Problem with rtems-libbsd build
Hello,
----- Am 28. Sep 2018 um 17:18 schrieb Jeff Mayes Jeff.Mayes at OARcorp.com:
> Hi
> Pulled rtems and rtems-libbsd yesterday.  Then, built rtems for
> powerpc and
> qoriq_core_0 successfully.
out of curiosity, why did you choose this BSP variant?
> Trying to build rtems-libbsd now, but getting this error below.  Any
> ideas?
> Thanks in advance
> [1433/2034] Compiling freebsd/sys/dev/sdhci/fsl_sdhci.c
> ../../freebsd/sys/dev/sdhci/fsl_sdhci.c:70:10: fatal error:
> powerpc/mpc85xx/mpc85xx.h: No such file or directory #include
> <powerpc/mpc85xx/mpc85xx.h>
>                  ^~~~~~~~~~~~~~~~~~~~~~~~~~ compilation terminated.
Sorry for the trouble, this should be fixed now.
