Problem with rtems-libbsd build
    Joel Sherrill
    joel at rtems.org
    Fri Sep 28 18:29:51 UTC 2018
Which arm and powerpc bsps would you recommend as known to really work with
libbsd?
Jeff was just doing API presence compliance testing. I randomly recommended
that one.
On Fri, Sep 28, 2018, 2:03 PM Jeff Mayes <Jeff.Mayes at oarcorp.com> wrote:
> Joel's recommendation on the BSP variant.  Just trying to do some plain
> vanilla testing on powerpc.
> Thanks!
> -----Original Message-----
> From: Sebastian Huber <sebastian.huber at embedded-brains.de>
> Sent: Friday, September 28, 2018 11:10 AM
> To: Jeff Mayes <Jeff.Mayes at OARcorp.com>
> Cc: devel <devel at rtems.org>
> Subject: Re: Problem with rtems-libbsd build
> Hello,
> ----- Am 28. Sep 2018 um 17:18 schrieb Jeff Mayes Jeff.Mayes at OARcorp.com:
> > Hi
> > Pulled rtems and rtems-libbsd yesterday.  Then, built rtems for
> > powerpc and
> > qoriq_core_0 successfully.
> out of curiosity, why did you choose this BSP variant?
> > Trying to build rtems-libbsd now, but getting this error below.  Any
> > ideas?
> > Thanks in advance
> > [1433/2034] Compiling freebsd/sys/dev/sdhci/fsl_sdhci.c
> > ../../freebsd/sys/dev/sdhci/fsl_sdhci.c:70:10: fatal error:
> > powerpc/mpc85xx/mpc85xx.h: No such file or directory #include
> > <powerpc/mpc85xx/mpc85xx.h>
> >                  ^~~~~~~~~~~~~~~~~~~~~~~~~~ compilation terminated.
> Sorry for the trouble, this should be fixed now.
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180928/4af3364c/attachment-0002.html>
