rtems-libbsd build error
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sun Apr 7 12:50:03 UTC 2019
On Sun, Apr 7, 2019 at 6:08 PM Christian Mauderer <list at c-mauderer.de>
wrote:
> Am 07.04.19 um 14:35 schrieb Vijay Kumar Banerjee:
> > On Sun, Apr 7, 2019 at 5:37 PM Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> > Am 07.04.19 um 13:08 schrieb Vijay Kumar Banerjee:
> > > Hi,
> > > I had a look at the files related to HDMI drivers, to figure out
> > separate
> > > compilable parts that can be imported together and ported to RTEMS.
> > > I figured that the import can be done in two parts, one for
> am335x_lcd
> > > and one for the tda19988 framer. I have also opened a new branch
> for
> > > am335x_lcd and have done a clean import and some basic first part
> of
> > > the porting.
> > > https://github.com/thelunatic/rtems-libbsd/tree/am335x_lcd
> > > I had a look at the CONTRIBUTING guide and have also generated the
> > > rtems-bsd-kernel-namespace.h ( not yet pushed to the remote)
> > > Does it look good to you?
> > > What is the next set of things to do to port it to RTEMS?
> > Hello Vijay,
> > does everything compile and link correctly? If yes: does the software
> > run on the target and is the hardware detected during boot without
> > throwing an exception somewhere?
> > I have checked that everything compiles and links properly with the
> commits.
> > But Unfortunately, I don't have an lcd display module right now. I only
> > have a
> > standard monitor that works with hdmi cable ( checked it to be working
> with
> > FreeBSD image). To work with the HDMI port, I think we'll need the
> > tda driver
> > imported as well.
> > Is it alright if I create another set of commits to import the
> > tda driver as well, and
> > then try to run it in the target with HDMI?
> You want to test more than I intended. My main concern was whether the
> BSP still runs without throwing an exception.
> Okay, I'll test this.
Is running the hello world application through gdbserver, enough to check
that it works without exception?
Is there a way to run multiple exes? If I'm asking something that can be
found
in the docs, a link would help. I couldn't find at first search. :)
> For testing the whole system together another set of patches importing
> the tda driver is OK.
> > From a quick look at the patches I would move the generated files (in
> > rtemsbsd directory) to the port commit so that the import commit
> really
> > only contains unchanged imported files. But that is a matter of
> opinion.
> > Understood. I'll move them to the port commit.
> > Best regards
> > Christian
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190407/2e2b0705/attachment-0001.html>
