rtems-libbsd build error
Christian Mauderer list at c-mauderer.de
Sun Apr 7 12:54:52 UTC 2019
Am 07.04.19 um 14:50 schrieb Vijay Kumar Banerjee:
> On Sun, Apr 7, 2019 at 6:08 PM Christian Mauderer <list at c-mauderer.de
> <mailto:list at c-mauderer.de>> wrote:
>     Am 07.04.19 um 14:35 schrieb Vijay Kumar Banerjee:
>     > On Sun, Apr 7, 2019 at 5:37 PM Christian Mauderer
>     <list at c-mauderer.de <mailto:list at c-mauderer.de>
>     > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
>     >     Am 07.04.19 um 13:08 schrieb Vijay Kumar Banerjee:
>     >     > Hi,
>     >     > I had a look at the files related to HDMI drivers, to figure out
>     >     separate
>     >     > compilable parts that can be imported together and ported to
>     RTEMS.
>     >     > I figured that the import can be done in two parts, one for
>     am335x_lcd
>     >     > and one for the tda19988 framer. I have also opened a new
>     branch for
>     >     > am335x_lcd and have done a clean import and some basic first
>     part of
>     >     > the porting.
>     >     > https://github.com/thelunatic/rtems-libbsd/tree/am335x_lcd
>     >     > I had a look at the CONTRIBUTING guide and have also
>     generated the
>     >     > rtems-bsd-kernel-namespace.h ( not yet pushed to the remote)
>     >     > Does it look good to you?
>     >     > What is the next set of things to do to port it to RTEMS?
>     >     Hello Vijay,
>     >     does everything compile and link correctly? If yes: does the
>     software
>     >     run on the target and is the hardware detected during boot without
>     >     throwing an exception somewhere?
>     > I have checked that everything compiles and links properly with
>     the commits.
>     > But Unfortunately, I don't have an lcd display module right now. I
>     only
>     > have a
>     > standard monitor that works with hdmi cable ( checked it to be
>     working with
>     > FreeBSD image). To work with the HDMI port, I think we'll need the
>     > tda driver
>     > imported as well.
>     > Is it alright if I create another set of commits to import the
>     > tda driver as well, and
>     > then try to run it in the target with HDMI?
>     You want to test more than I intended. My main concern was whether the
>     BSP still runs without throwing an exception.
> Okay, I'll test this.
> Is running the hello world application through gdbserver, enough to check
> that it works without exception?
> Is there a way to run multiple exes? If I'm asking something that can be
> found
> in the docs, a link would help. I couldn't find at first search. :)
I don't think that there are a lot of docs for how to test. Although I'm
sure that there are some scripts to run a number of libbsd tests, I'm
not sure where. Maybe in the RTEMS tester but I think that is mainly for
the core tests?
My approach would be to run one of the tests that do something more like
the media01 from libbsd  (you boot into a shell in that test) and take a
look whether there are some boot messages regarding the driver. Most
libbsd drivers tend to tell you that they found their device.
>     For testing the whole system together another set of patches importing
>     the tda driver is OK.
>     >     From a quick look at the patches I would move the generated
>     files (in
>     >     rtemsbsd directory) to the port commit so that the import
>     commit really
>     >     only contains unchanged imported files. But that is a matter
>     of opinion.
>     > Understood. I'll move them to the port commit.
>     >     Best regards
>     >     Christian
