rtems-libbsd build error
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sun Apr 7 14:30:41 UTC 2019
On Sun, Apr 7, 2019 at 6:24 PM Christian Mauderer <list at c-mauderer.de>
wrote:
> Am 07.04.19 um 14:50 schrieb Vijay Kumar Banerjee:
> > On Sun, Apr 7, 2019 at 6:08 PM Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> > Am 07.04.19 um 14:35 schrieb Vijay Kumar Banerjee:
> > > On Sun, Apr 7, 2019 at 5:37 PM Christian Mauderer
> > <list at c-mauderer.de <mailto:list at c-mauderer.de>
> > > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
> > > Am 07.04.19 um 13:08 schrieb Vijay Kumar Banerjee:
> > > > Hi,
> > > > I had a look at the files related to HDMI drivers, to figure
> out
> > > separate
> > > > compilable parts that can be imported together and ported to
> > RTEMS.
> > > > I figured that the import can be done in two parts, one for
> > am335x_lcd
> > > > and one for the tda19988 framer. I have also opened a new
> > branch for
> > > > am335x_lcd and have done a clean import and some basic first
> > part of
> > > > the porting.
> > > > https://github.com/thelunatic/rtems-libbsd/tree/am335x_lcd
> > > > I had a look at the CONTRIBUTING guide and have also
> > generated the
> > > > rtems-bsd-kernel-namespace.h ( not yet pushed to the remote)
> > > > Does it look good to you?
> > > > What is the next set of things to do to port it to RTEMS?
> > > Hello Vijay,
> > > does everything compile and link correctly? If yes: does the
> > software
> > > run on the target and is the hardware detected during boot
> without
> > > throwing an exception somewhere?
> > > I have checked that everything compiles and links properly with
> > the commits.
> > > But Unfortunately, I don't have an lcd display module right now. I
> > only
> > > have a
> > > standard monitor that works with hdmi cable ( checked it to be
> > working with
> > > FreeBSD image). To work with the HDMI port, I think we'll need the
> > > tda driver
> > > imported as well.
> > > Is it alright if I create another set of commits to import the
> > > tda driver as well, and
> > > then try to run it in the target with HDMI?
> > You want to test more than I intended. My main concern was whether
> the
> > BSP still runs without throwing an exception.
> > Okay, I'll test this.
> > Is running the hello world application through gdbserver, enough to
> check
> > that it works without exception?
> > Is there a way to run multiple exes? If I'm asking something that can be
> > found
> > in the docs, a link would help. I couldn't find at first search. :)
> I don't think that there are a lot of docs for how to test. Although I'm
> sure that there are some scripts to run a number of libbsd tests, I'm
> not sure where. Maybe in the RTEMS tester but I think that is mainly for
> the core tests?
> so far I know, RTEMS Tester is only for core tests. I'll ask in the devel
if there's
some way to run libbsd test with the tester.
> My approach would be to run one of the tests that do something more like
> the media01 from libbsd (you boot into a shell in that test) and take a
> look whether there are some boot messages regarding the driver. Most
> libbsd drivers tend to tell you that they found their device.
> I have tried running media01.exe and it seems to run fine and I see this
nice
line during cpu starting
fb0: <AM335x LCD controller> mem 0x4830e000-0x4830efff irq 36 on simplebus0
> > For testing the whole system together another set of patches
> importing
> > the tda driver is OK.
> > > From a quick look at the patches I would move the generated
> > files (in
> > > rtemsbsd directory) to the port commit so that the import
> > commit really
> > > only contains unchanged imported files. But that is a matter
> > of opinion.
> > > Understood. I'll move them to the port commit.
> > > Best regards
> > > Christian
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190407/b6d05aa6/attachment.html>
