[rtems-test] powerpc/psim: RTEMS_POSIX_API: Passed:560 Failed:14 Timeout:5 Invalid:0 Wrong:0
Thu Apr 11 22:17:15 UTC 2019
Hi Joel,
Thank you for running these tests and publishing the results.
On 12/4/19 8:10 am, joel at rtems.org wrote:
> Testing time     : 0:10:37.757133
> Average test time: 0:00:01.084621
> Host
> Linux-3.10.0-862.11.6.el7.x86_64-x86_64-with-centos-7.5.1804-Core (Linux rtbf64c.rtems.com 3.10.0-862.11.6.el7.x86_64 #1 SMP Tue Aug 14 21:49:04 UTC 2018 x86_64 x86_64)
> Configuration
> Version: 5.0.0.ad87de4a67d8ce7e75d0b844efc03b98c3ecda1a
> Build  : RTEMS_POSIX_API
> Tools  : 7.4.0 20181206 (RTEMS 5, RSB 9a3e12e5820918057633798c3fe2a1f952fb4e56, Newlib 1d35a003f)
> Summary
> Passed:        560
> Failed:         14
> User Input:      6
> Expected Fail:   0
> Indeterminate:   0
> Benchmark:       3
> Timeout:         5
> Invalid:         0
> Wrong Version:   0
> Wrong Build:     0
> Wrong Tools:     0
> Total:         588
> Failures:
>  fsimfsgeneric01.exe
>  block11.exe
>  devfs02.exe
>  rbheap01.exe
>  termios01.exe
>  psx12.exe
>  psxchroot01.exe
>  psximfs02.exe
>  psxpipe01.exe
>  spconfig02.exe
>  spfatal31.exe
>  spmountmgr01.exe
>  spprivenv01.exe
>  spstdthreads01.exe
> User Input:
>  dl10.exe
>  monitor.exe
>  termios.exe
>  top.exe
>  capture.exe
>  fileio.exe
> Benchmark:
>  whetstone.exe
>  dhrystone.exe
>  linpack.exe
> Timeouts:
>  fsrfsbitmap01.exe
>  dl08.exe
>  dl09.exe
The `dl.*` test timeouts look like the test is running too long and if you have
a number of tests running at once this could be the reason.
I see a couple of possible solutions, adding timeout control to the tests which
rtems-test can see of I can drop the loop count to 10. The loop count is the
simplest.
The loop lets me see a repeating set of addresses being used so I can check for
leaks.
