[rtems-test] powerpc/psim: RTEMS_POSIX_API: Passed:560 Failed:14 Timeout:5 Invalid:0 Wrong:0
Joel Sherrill
joel at rtems.org
Thu Apr 11 22:35:57 UTC 2019
On Thu, Apr 11, 2019 at 5:16 PM Chris Johns <chrisj at rtems.org> wrote:
> Hi Joel,
> Thank you for running these tests and publishing the results.
:) I'm trying to build up my "rtems-cron" script. Not the fanciest way to
decide when to test things but it will know how to test them.
It will eventually run Coverity
Any advice on knowing in a script if git needs to update a repo or a pull
updated? I thought this would work but it didn't show the rtems updates
today:
git rev-list HEAD...origin/master --count
> On 12/4/19 8:10 am, joel at rtems.org wrote:
> > Testing time : 0:10:37.757133
> > Average test time: 0:00:01.084621
> > Host
> > Linux-3.10.0-862.11.6.el7.x86_64-x86_64-with-centos-7.5.1804-Core (Linux
> rtbf64c.rtems.com 3.10.0-862.11.6.el7.x86_64 #1 SMP Tue Aug 14 21:49:04
> UTC 2018 x86_64 x86_64)
> > Configuration
> > Version: 5.0.0.ad87de4a67d8ce7e75d0b844efc03b98c3ecda1a
> > Build : RTEMS_POSIX_API
> > Tools : 7.4.0 20181206 (RTEMS 5, RSB
> 9a3e12e5820918057633798c3fe2a1f952fb4e56, Newlib 1d35a003f)
> > Summary
> > Passed: 560
> > Failed: 14
> > User Input: 6
> > Expected Fail: 0
> > Indeterminate: 0
> > Benchmark: 3
> > Timeout: 5
> > Invalid: 0
> > Wrong Version: 0
> > Wrong Build: 0
> > Wrong Tools: 0
> > Total: 588
> > Failures:
> > fsimfsgeneric01.exe
> > block11.exe
> > devfs02.exe
> > rbheap01.exe
> > termios01.exe
> > psx12.exe
> > psxchroot01.exe
> > psximfs02.exe
> > psxpipe01.exe
> > spconfig02.exe
> > spfatal31.exe
> > spmountmgr01.exe
> > spprivenv01.exe
> > spstdthreads01.exe
> > User Input:
> > dl10.exe
> > monitor.exe
> > termios.exe
> > top.exe
> > capture.exe
> > fileio.exe
> > Benchmark:
> > whetstone.exe
> > dhrystone.exe
> > linpack.exe
> > Timeouts:
> > fsrfsbitmap01.exe
> > dl08.exe
> > dl09.exe
> The `dl.*` test timeouts look like the test is running too long and if you
> have
> a number of tests running at once this could be the reason.
When run by hand, dl08 passes with this much time used:
real 0m7.194s
user 0m5.997s
sys 0m0.703s
dl09 is less. Those aren't very long. I don't know why they timeout with
the tester.
fsrfsbitmap01 is over 4.5 minutes of host CPU time and stuck here:
23. Cleared bit still set: bit = 126
Testing bitmap_map functions with zero initialized bitmap control pointer
Allocate most of memory - attempt to fail while open bitmap - expect ENOMEM
I will let it continue overnight but this one is either hung or needs
tweaking to
consume most of memory a single large allocation and then force the the rfs
bitmap error.
> I see a couple of possible solutions, adding timeout control to the tests
> which
> rtems-test can see of I can drop the loop count to 10. The loop count is
> the
> simplest.
> The loop lets me see a repeating set of addresses being used so I can
> check for
> leaks.
I don't think that's the issue. The dl tests run quickly by hand.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190411/c48942c7/attachment-0002.html>
