RTEMS SMP on Raspberry Pi 2
    Ricardo Gomes (1161078)
    1161078 at isep.ipp.pt
    Thu Aug  1 10:49:03 UTC 2019
Hello everyone,
I'm trying to collect some results of some experiments that I'm doing related with synchronization mechanisms for SMPs.
So far, I have the results for QEMU but I'm trying to use a Raspberry Pi 2 to obtain results in real hardware.
I saw the new patches that were recently added for the raspberry pi bsp and as mentioned in the emails related to the new patches I changed the start address to 0x200000.
However, I have a problem running my samples in the board. The kernel compiles without any problem. I'm using the following commands to compile it:
arm-rtems5-objcopy -Obinary
Now the issue occurs when I try to execute my tests for SMP, as the kernel freezes during the boot loader first stage.
As a side note, when I compile and execute something para single processor na RPi2 I don't have any issue. The issue only occurs when dealing with SMP.
Can someone help me in figuring out what I'm doing wrong?
Thanks in advance.
Regards,
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190801/90b81350/attachment.html>
