GSoC Project | Basic Support for Trace Compass
Sebastian Huber
Fri Aug 2 08:38:10 UTC 2019
On 31/07/2019 08:30, Ravindra Kumar Meena wrote:
> > The bit field is documented in the manual. I would simplify this to:
> > cctx->switch_out_int[ item->cpu ].prev_state = ( ( ( item->data
> >> 24 )
> > & 0x7 ) == 1 ) ? TASK_IDLE : TASK_RUNNING;
> Did you check how the Trace Compass behaviour changed with this?
> Yes. I imported the trace on Trace Compass. The CPU 5 Threads and CPU 5
> States lines are straight in the beginning because there is no change in
> the cpu_id. At the end of the trace, there is a lot of change in cpu_id
> due to which Trace Compass shows other CPU thread and state lines.
> I have attached the screenshot of trace compass. Have a look.
Yes, this is similar to what I see. I don't think this is what we want.
The 09.. are all idle threads. What I want is something similar to the
LTTNG output, see attached screen shot.
It seems the prev_state is actually the state of the new thread. Doesn't
really make sense to me. Could you please clarify this with the LTTNG
mailing list?
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190802/fb19d7c3/attachment-0001.png>
