GSoC Project | Basic Support for Trace Compass
Fri Aug 2 08:45:45 UTC 2019
On 02/08/2019 10:38, Sebastian Huber wrote:
> On 31/07/2019 08:30, Ravindra Kumar Meena wrote:
>>      > The bit field is documented in the manual. I would simplify
>> this to:
>>      > cctx->switch_out_int[ item->cpu ].prev_state = ( ( ( item->data
>>      >> 24 )
>>      > & 0x7 ) == 1 ) ? TASK_IDLE : TASK_RUNNING;
>>     Did you check how the Trace Compass behaviour changed with this?
>> Yes. I imported the trace on Trace Compass. The CPU 5 Threads and CPU
>> 5 States lines are straight in the beginning because there is no
>> change in the cpu_id. At the end of the trace, there is a lot of
>> change in cpu_id due to which Trace Compass shows other CPU thread and
>> state lines.
>> I have attached the screenshot of trace compass. Have a look.
> Yes, this is similar to what I see. I don't think this is what we want.
> The 09.. are all idle threads. What I want is something similar to the
> LTTNG output, see attached screen shot.
> It seems the prev_state is actually the state of the new thread. Doesn't
> really make sense to me. Could you please clarify this with the LTTNG
> mailing list?
It seems that there are some special cases for the swapper which has a
tid of 0. Could you please adjust the code so that idle threads get a
tid of 0.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
