RISCV BSP
Fri Aug 2 17:14:20 UTC 2019
 Seems you will need 2 more spike to cover the suggestion 32/64 and
HW/SW FP? i also recommend you try the sis variant, for a bit more
coverage.
On Fri, Aug 2, 2019 at 10:27 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
> Thanks a lot.
> Then I will be working with "rv32imac" and "rv64imac"
> Vaibhav Gupta
> On Fri, Aug 2, 2019 at 1:33 PM Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> On 02/08/2019 09:50, Vaibhav Gupta wrote:
>> > Hello,
>> > I was about to test the testsuite code, need to confirm
>> > on which RISCV BSP we are going to work?
>> > For example, for ARM I was asked for xilinx-zynq
>> > So is there any specific one for riscv too, or should I build any of it?
>> While you work on this, please review the documentation.
>> https://docs.rtems.org/branches/master/user/bsps/bsps-riscv.html
>> Feel free to send documentation patches. There is support for some
>> RISC-V BSPs in the RTEMS Tester:
>> ./tester/rtems/testing/bsps/griscv-sis.ini
>> ./tester/rtems/testing/bsps/griscv.ini
>> ./tester/rtems/testing/bsps/griscv-sis-cov.ini
>> ./tester/rtems/testing/bsps/rv32imac_spike.ini
>> ./tester/rtems/testing/bsps/rv64imafdc_spike.ini
>> ./tester/rtems/testing/bsps/rv64imafd_spike.ini
>> ./tester/rtems/testing/bsps/rv64imafd_medany.ini
>> ./tester/rtems/testing/bsps/rv64imafd_medany_spike.ini
>> ./tester/rtems/testing/bsps/rv32imafc_spike.ini
>> ./tester/rtems/testing/bsps/rv32imafd_spike.ini
>> ./tester/rtems/testing/bsps/rv64imac_medany_spike.ini
>> ./tester/rtems/testing/bsps/rv32im_spike.ini
>> ./tester/rtems/testing/bsps/rv64imac_spike.ini
>> ./tester/rtems/testing/bsps/rv32imafdc_spike.ini
>> ./tester/rtems/testing/bsps/rv32iac_spike.ini
>> ./tester/rtems/testing/bsps/rv64imafdc_medany_spike.ini
>> ./tester/rtems/testing/bsps/rv32i_spike.ini
>> I would test on a 32-bit and 64-bit variant. Also with hardware FP and
>> without.
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
