RISCV BSP
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Mon Aug 5 12:59:58 UTC 2019
On Fri, Aug 2, 2019 at 10:44 PM Gedare Bloom <gedare at rtems.org> wrote:
> Seems you will need 2 more spike to cover the suggestion 32/64 and
> HW/SW FP?
Yes, moreover I will need good amount of guidance too.
> i also recommend you try the sis variant, for a bit more
> coverage.
Okay, I will do that.
For now I wanted to test my code for testsuite. Basic tests for now,
then can move to Floating Point Unit.
> On Fri, Aug 2, 2019 at 10:27 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> > Thanks a lot.
> > Then I will be working with "rv32imac" and "rv64imac"
> > Vaibhav Gupta
> > On Fri, Aug 2, 2019 at 1:33 PM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
> >> On 02/08/2019 09:50, Vaibhav Gupta wrote:
> >> > Hello,
> >> > I was about to test the testsuite code, need to confirm
> >> > on which RISCV BSP we are going to work?
> >> > For example, for ARM I was asked for xilinx-zynq
> >> > So is there any specific one for riscv too, or should I build any of
> it?
> >> While you work on this, please review the documentation.
> >> https://docs.rtems.org/branches/master/user/bsps/bsps-riscv.html
> >> Feel free to send documentation patches. There is support for some
> >> RISC-V BSPs in the RTEMS Tester:
> >> ./tester/rtems/testing/bsps/griscv-sis.ini
> >> ./tester/rtems/testing/bsps/griscv.ini
> >> ./tester/rtems/testing/bsps/griscv-sis-cov.ini
> >> ./tester/rtems/testing/bsps/rv32imac_spike.ini
> >> ./tester/rtems/testing/bsps/rv64imafdc_spike.ini
> >> ./tester/rtems/testing/bsps/rv64imafd_spike.ini
> >> ./tester/rtems/testing/bsps/rv64imafd_medany.ini
> >> ./tester/rtems/testing/bsps/rv64imafd_medany_spike.ini
> >> ./tester/rtems/testing/bsps/rv32imafc_spike.ini
> >> ./tester/rtems/testing/bsps/rv32imafd_spike.ini
> >> ./tester/rtems/testing/bsps/rv64imac_medany_spike.ini
> >> ./tester/rtems/testing/bsps/rv32im_spike.ini
> >> ./tester/rtems/testing/bsps/rv64imac_spike.ini
> >> ./tester/rtems/testing/bsps/rv32imafdc_spike.ini
> >> ./tester/rtems/testing/bsps/rv32iac_spike.ini
> >> ./tester/rtems/testing/bsps/rv64imafdc_medany_spike.ini
> >> ./tester/rtems/testing/bsps/rv32i_spike.ini
> >> I would test on a 32-bit and 64-bit variant. Also with hardware FP and
> >> without.
> >> Sebastian Huber, embedded brains GmbH
> >> Address : Dornierstr. 4, D-82178 Puchheim, Germany
> >> Phone : +49 89 189 47 41-16
> >> Fax : +49 89 189 47 41-09
> >> E-Mail : sebastian.huber at embedded-brains.de
> >> PGP : Public key available on request.
> >> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190805/a5ba66e9/attachment.html>
