GSoC Project | Basic Support for Trace Compass
Fri Aug 2 17:46:17 UTC 2019
----- Am 2. Aug 2019 um 19:14 schrieb Ravindra Kumar Meena rmeena840 at gmail.com:
>> It seems that there are some special cases for the swapper which has a
>> tid of 0. Could you please adjust the code so that idle threads get a
>> tid of 0.
> Done. The graph now has more detail now. I have attached the screenshot.
> Earlier there was a straight line in the beginning. The histogram graph has
> also changed.
> https://github.com/rmeena840/rtems-tools/commit/12cc758befee3e415d0f133288aa7af04ee1572e
You have to set the tid to zero in each of the two fields if you have a corresponding idle thread.
