Graphics libraries in RTEMS
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Tue Aug 6 06:56:53 UTC 2019
On Tue, Aug 6, 2019 at 3:50 AM Chris Johns <chrisj at rtems.org> wrote:
> On 6/8/19 1:42 am, Vijay Kumar Banerjee wrote:
> > Hello all,
> > I now have a working framebuffer driver for Beablebone black where I
> > can already print a picture on the screen. I'm starting to explore the
> > graphics libraries as the next step in my project.
> > I have had a look at the RTEMS Graphics toolkit and have built a few
> > graphics packages from RSB. What's the state of this toolkit and is there
> > and a sample application built using these libraries that I can take as
> > a reference?
> Some build and some are broken. This ticket
> https://devel.rtems.org/ticket/3770
> captures the current state. I am not sure how active these projects are.
> > There's also another library mentioned by Chris at some point in time.
> > https://github.com/littlevgl/lvgl
> > This library also looks very interesting for building GUI apps in
> embedded
> > systems.
> > Which library should I start working with and maybe try to port to RTEMS?
> > Any advice on where to get started?
> I would start with littlevgl. I am using it on Linux and it works well. The
> project is hosted on GitHub and there is a forum that is active. I would
> start
> with the latest version.
> OK. I'll start with littlevgl, thanks.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190806/c80998a7/attachment.html>
