Chapter/section numbers in document internal references
Tue Aug 6 08:05:46 UTC 2019
On 6/8/19 4:36 pm, Sebastian Huber wrote:
> Hello,
> when you use document internal references, e.g.
> :ref:`RSB`
> then this is turned into:
> "Chapter 12 - RTEMS Source Builder"
> I think this "Chapter 12 - " prefix makes it harder to read the document. In a
> default configuration of Sphinx this stuff is not included. Would it be possible
> to remove this from the RTEMS customization?
What are you suggesting instead? Could you put something online so I could compare?
I did play around with this but I cannot remember all the variations and why I
selected this one.
Thanks
