GSoC Project | Basic Support for Trace Compass
    Ravindra Kumar Meena
    rmeena840 at gmail.com
    Tue Aug  6 08:26:14 UTC 2019
> Thread name is in the right order now.
> Yes, the order is all right, but you still overwrite thread names which
> consist of multiple events.
I am not able to figure out how overwritten is happening. In my code
overwritten case is handled by:
if( cctx->thread_names[ api_id ][ thread_id ][ i ] == 0x00 )
The above line means that write value only if a NULL char position is
available. When we receive first RTEMS_RECORD_THREAD_NAME the loop will
start filling the NULL char position from the beginning and when second
RTEMS_RECORD_THREAD_NAME is received then NULL char are filled just after
the previously filled char position.
e.g.
Object Index: 30
After the first iteration of for loop, the 16 size char array will be:
{s,w,i,6,0,0,0,0,0,0,0,0,0,0,0,0}
After the second iteration of for loop, the 16 size char array will be:
{s,w,i,6,s,k, ,q,0,0,0,0,0,0,0,0}
For this decode, the value will be "swi6sk q". Right? This is exactly what
I am getting in Konsole.
*Ravindra Kumar Meena*,
B. Tech. Computer Science and Engineering,
Indian Institute of Technology (Indian School of Mines)
<https://www.iitism.ac.in/>, Dhanbad
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190806/4fd55359/attachment.html>
