GSoC Project | Basic Support for Trace Compass
    Sebastian Huber
    Tue Aug  6 08:38:51 UTC 2019
On 06/08/2019 10:26, Ravindra Kumar Meena wrote:
>     Thread name is in the right order now.
>     Yes, the order is all right, but you still overwrite thread names which
>     consist of multiple events.
> I am not able to figure out how overwritten is happening. In my code
> overwritten case is handled by:
> if( cctx->thread_names[ api_id ][ thread_id ][ i ] == 0x00 )
This check is wrong, you should not rely on previous content of this
buffer. If you see the first RTEMS_RECORD_THREAD_NAME event, then you
should overwrite the complete 16 chars with 0 and fill it up with the
new content. In the first RTEMS_RECORD_THREAD_NAME event, you fill up
chars 0..7, in the second 8..15.  For this you have to store somehow
thread_id_name on which position you are, e.g.
typedef struct thread_id_name{
   uint64_t thread_id;
   size_t name_index;
} thread_id_name;
Set name_index to 0 if you see a RTEMS_RECORD_THREAD_ID event. Increment
it by one after you processed a RTEMS_RECORD_THREAD_NAME event.
> The above line means that write value only if a NULL char position is
> available. When we receive first RTEMS_RECORD_THREAD_NAME the loop will
> start filling the NULL char position from the beginning and when second
> RTEMS_RECORD_THREAD_NAME is received then NULL char are filled just
> after the previously filled char position.
> e.g.
> Object Index: 30
On a 64-bit target, the data field contains 8 chars. Why do you only
print 4 chars here?
> After the first iteration of for loop, the 16 size char array will be:
> {s,w,i,6,0,0,0,0,0,0,0,0,0,0,0,0}
> After the second iteration of for loop, the 16 size char array will be:
> {s,w,i,6,s,k, ,q,0,0,0,0,0,0,0,0}
> For this decode, the value will be "swi6sk q". Right? This is exactly
> what I am getting in Konsole.
For this task you should end up with "swi6: task queu".
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
