[PATCH] user: Improve bug report section
Sebastian Huber
Tue Aug 6 10:01:07 UTC 2019
The new content is based on the wiki page:
https://devel.rtems.org/wiki/Developer/Bug_Reporting
The goal is to remove the wiki page and direct the "New ticket" page to
this user manual section. Some content of the wiki page should move to
the "Contributing" sections since it is not directly related to bug
reporting, e.g. managing existing bugs.
user/index.rst | 3 +-
user/support/bugs.rst | 187 ++++++++++++++++++++++++++++++++++--
user/support/contrib.rst | 2 +
user/support/support-commercial.rst | 2 +
4 files changed, 183 insertions(+), 11 deletions(-)
diff --git a/user/index.rst b/user/index.rst
index 6491c6c..eff85f3 100644
--- a/user/index.rst
+++ b/user/index.rst
@@ -16,7 +16,8 @@ RTEMS User Manual (|version|).
| |copy| 2017 Tanu Hari Dixit
| |copy| 2016, 2019 embedded brains GmbH
| |copy| 2016, 2019 Sebastian Huber
- | |copy| 2012, 2019 Chris Johns
+ | |copy| 2012, 2019 Chris Johns
+ | |copy| 2012 Gedare Bloom
| |copy| 1988, 2018 On-Line Applications Research Corporation (OAR)
.. include:: ../common/license.rst
diff --git a/user/support/bugs.rst b/user/support/bugs.rst
index 1ad1b5f..16d58cc 100644
--- a/user/support/bugs.rst
+++ b/user/support/bugs.rst
@@ -2,21 +2,188 @@
.. Copyright (C) 2019 embedded brains GmbH
.. Copyright (C) 2019 Sebastian Huber
-.. Copyright (C) 2016 Chris Johns <chrisj at rtems.org>
+.. Copyright (C) 2015 Chris Johns <chrisj at rtems.org>
+.. Copyright (C) 2012 Gedare Bloom
.. index:: bugs
.. index:: reporting bugs
-Bugs
+Report Bugs
-The bug tracker can be found at the :r:url:`bugs`.
+The RTEMS Project uses a ticket system to deal with bugs, organize enhancement
+requests, and manage small tasks and projects. You can `submit a bug report
+<https://devel.rtems.org/newticket>`_ to the RTEMS Project ticket system.
+Before you do this, please read the following information. Good bug reports
+are more likely to get addressed quickly. If you have patches not specifically
+related to bugs or existing tickets, please have a look at the
+:ref:`Contributing` guidelines.
-See the `Submission Guidelines <http://devel.rtems.org/wiki/NewTicket/>`_ for
-details on submitting a ticket.
+Search for Existing Bugs
-Be sure to do a cursory search for any tickets that may be relevant to your
-problem.
+You can `search for existing bugs <https://devel.rtems.org/query>`_ in the
+RTEMS Project ticket system. Please try to avoid duplicate bug reports and
+search for an existing bug before you report a new bug. If you are unsure,
+please ask on the :r:list:`users` and we will help you sort it out.
-If you are unsure about your issue status submit a ticket and we will help you
-sort it out.
+No RTEMS Bugs
+Some issues appear to be an RTEMS bug to you, but are actually the intended
+behaviour or in the scope of other projects.
+* Bugs in the assembler, the linker, or the C library (Newlib) are no RTEMS
+ bugs. These are separate projects, with separate mailing lists and different
+ bug reporting procedures. The RTEMS Project is happy to work with you and
+ those projects to resolve the problem but we must work with those projects.
+ Bugs in those products must be addressed in the corresponding project. Report
+ `assembler, linker, and GDB bugs to sourceware.org <https://sourceware.org/bugzilla/enter_bug.cgi>`_,
+ `compiler bugs to GCC <https://gcc.gnu.org/bugzilla/enter_bug.cgi>`_, and
+ `Newlib bugs to the mailing list <https://sourceware.org/newlib/>`_.
+ If the bug was fixed, then you can update the :ref:`RSB` to pick up the fix.
+* Questions about the correctness or the expected behaviour of programming
+ language constructs or calls to library routines that are not part of RTEMS
+ belong to somewhere else.
+* The POSIX standard does *not* specify the default set of thread attributes.
+ Thus, when passing a NULL for attributes to pthread_create(), the application
+ is not guaranteed any particular thread behaviour.
+* The defaults for all
+ `RTEMS Application Configuration <https://docs.rtems.org/branches/master/c-user/configuring_a_system.html>`_
+ parameters are intentionally small. Thus, it is common for RTEMS tasking and
+ file related calls to return errors indicating out of resources until the
+ configuration parameters are properly tuned for the application. For example,
+ there are only three file descriptors available by default: stdin, stdout, and
+ stderr. Any attempt to open a socket or file will fail unless more file
+ descriptors are configured.
+* When first developing a BSP, many users encounter an unexpected interrupt or
+ exception immediately upon completion of RTEMS initialization. This occurs
+ because interrupts are disabled during RTEMS initialization and are
+ automatically initialized as part of switching to the first task. The
+ interrupted user code will be in either _CPU_Context_switch() or
+ _Thread_Handler(). This indicates that an interrupt source has not been
+ properly initialized or masked.
+* Some users encounter a random reset during BSP initialization. This usually
+ indicates that the board has a watchdog timer that is not being properly
+ serviced during the BSP initialization.
+* Bugs in releases or snapshots of RTEMS not issued by the RTEMS Project.
+ Report them to whoever provided you with the release.
+Good Bug Reports
+Please open the page to `submit a bug <https://devel.rtems.org/newticket>`_ to
+the RTEMS Project ticket system and follow the guidelines below to write a good
+bug report.
+* Provide a useful single line summary.
+* Use `WikiFormatting <https://devel.rtems.org/wiki/WikiFormatting>`_ to
+ structure the information you provide. It does help the readability of the
+ information you provide.
+* Add a description of the expected behaviour. The expected behaviour may be
+ obvious to you, but maybe not to someone else reading the bug report.
+* Add a description of the actual undesired behaviour.
+* Name the :ref:`target hardware <Hardware>` (processor architecture, chip family
+ or model, and :ref:`BSP <BSPs>`) in the description.
+* Add the toolchain version used (GCC, Binutils, Newlib) to the description.
+ Custom toolchain builds are discouraged. To avoid problems caused by custom
+ builds of the toolchain, please build your toolchain with the :ref:`RSB`. If
+ you use a custom build of the toolchain, then try to reproduce the bug first
+ using a toolchain built by the RSB.
+* Provide the configuration options used to build the RTEMS BSP in the
+ description. This helps to reproduce the issue.
+* Make the bug reproducible by others. Write a self-contained piece of source
+ code which can be compiled and reproduces the bug. Avoid adding assembly
+ files (\*.s) produced by the compiler, or any binary files, such as object
+ files, executables, core files, or precompiled header files. If it is
+ difficult or time consuming to reproduce the bug, then it may not get the
+ attention it deserves from others. Developing and debugging real-time
+ embedded systems can be difficult. Exercise caution in reporting an error
+ that occurs only some of the times a certain program is executed, such that
+ retrying a sufficient number of times results in a successful compilation;
+ this is often a symptom of a hardware problem or application issue, not of a
+ RTEMS bug (sorry). We do recognise that sometimes a timing bug will exist in
+ RTEMS, but we want you to exercise due diligence before pointing fingers.
+* Only when your bug report requires multiple source files to be reproduced
+ should you attach an archive. Otherwise, the uploaded individual source file
+ or diff should contain the minimal source code needed to reproduce the bug.
+ In any case, make sure the above are included in the body of your bug report
+ as plain text, even if needlessly duplicated as part of an archive.
+* Please try to reproduce the bug on the current Git master. If it is not
+ reproducible on the Git master, you should figure out if the bug was already
+ fixed. You can search the existing bugs once again, ask on the
+ :r:list:`users`, or do a Git bisect to find a commit which fixed the bug.
+* Include only information relevant to the bug.
+* Write separate bug reports for different bugs.
+* Select a *Type* for the ticket. Use ``defect`` for a bug. Note ``infra`` is
+ used to report issues with the RTEMS servers at OSUOSL.
+* Select a *Version* for the ticket. This should be the first RTEMS version
+ which is affected by this bug. If this is the current Git master branch use
+ the version of the next release. Please provide the exact version of RTEMS
+ in the description. If you use an RTEMS release, then the release number.
+ If you use a Git clone, then the commit hash. The commit hash should be
+ present in an RTEMS Project repository. Commit hashes of private branches
+ are not interesting.
+* Select a *Component* for the ticket. Use ``unspecified`` if you are unsure.
+* Select a *Severity* for the ticket.
+* The fields *Milestone* and *Priority* will be most likely set by an RTEMS
+ maintainer.
+* You can relate your new bug to existing bugs through the *Blocked by* and
+ *Blocking* fields.
+When you have checked that your report meets the criteria for a good bug
+report, please click on the ``Create ticket`` button to submit it to the RTEMS
+Project ticket system.
+If you fail to supply enough information for a bug report to be reproduced,
+someone will probably ask you to post additional information. In this case,
+please post the additional information and not just to the person who requested
+it, unless explicitly told so.
+Nobody Fixes my Bug
+Sometimes, you may notice that after some time your bug report gets no
+attention and the bug is not magically fixed. This may have several reasons
+* the bug report is incomplete or confusing,
+* the target hardware is not available to others,
+* the bug is not reproducible on the Git master,
+* the bug is not reproducible at all,
+* the RTEMS version is quite old and no longer used by RTEMS maintainers,
+* fixing the bug has a low priority for others.
+Please note that you do not have a service contract with the RTEMS Project.
+The RTEMS Project is run by volunteers and persons which take care about how
+RTEMS performs in their application domain. If your bug does not affect the
+interest of someone else, then you should try to fix the bug on your own, see
+the :ref:`Contributing` guidelines. To change the priorities of others with
+respect to your bug, you may refer to the :ref:`SupportCommercial`.
diff --git a/user/support/contrib.rst b/user/support/contrib.rst
index 11c6350..29c554d 100644
--- a/user/support/contrib.rst
+++ b/user/support/contrib.rst
@@ -6,6 +6,8 @@
.. index:: community; developers
+.. _Contributing:
Contributing
diff --git a/user/support/support-commercial.rst b/user/support/support-commercial.rst
index d3aebaa..665426b 100644
--- a/user/support/support-commercial.rst
+++ b/user/support/support-commercial.rst
@@ -4,6 +4,8 @@
.. index:: support; commercial
+.. _SupportCommercial:
Commercial Support Services
2.16.4
