Not able to run riscv-rv32imac testsuites
Vaibhav Gupta vaibhavgupta40 at gmail.com
Mon Aug 12 10:03:45 UTC 2019
Okay. Thanks
On Mon, Aug 12, 2019 at 3:00 PM Hesham Almatary <
hesham.almatary at cl.cam.ac.uk> wrote:
> On Mon, 12 Aug 2019 at 03:55, Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> > On Mon, Aug 12, 2019, 12:01 AM Hesham Almatary <
> >> On Sun, 11 Aug 2019 at 16:11, Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> >>> But I am not able to run:
> >>> qemu-system-riscv64 -no-reboot -nographic -machine virt -m 256M
> -kernel hello.exe
> >>> On Fri, Aug 9, 2019 at 2:53 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> >>>> I was able to run rv32imac using
> >>>> qemu-system-riscv32 -no-reboot -nographic -machine virt -m 256M
> -kernel hello.exe
> >>> When I configured rv32imac BSP with RISCV_ENABLE_HTIF_SUPPORT=1, This
> >> RISCV_ENABLE_HTIF_SUPPORT is only needed if you’re running on Spike.
> > Yeah, earlier i didn't use this parameter in configure. But when things
> were not working, I had to rebuilt BSP using it
> > And I used 'qemu-system-riscv64 -machine spike_v1.10...' but this too
> didn't worked.
> >> Which BSP are you building and running on QEMU?
> > Both rv32imac and rv64imac.
> > I am able to run rv32imac but not rv64imac.
> QEMU should be able to run "rv64imac_medany" and not "rv64imac". They
> have different DRAM_BASE and QEMU, AFAIK, only works with rv64*_medany
> which has 0x80000000 as a DRAM_BASE.
> > - Vaibhav
> >>> command prevents qemu from quitting properly I guess.
> >>> As after showing output, cursor still blinks and I quit it using
> 'pkill -9 qemu'.
> >>>> On Tue, Aug 6, 2019 at 9:04 PM Vaibhav Gupta <
> vaibhavgupta40 at gmail.com> wrote:
> >>>>> Awesome, thanks!
> >>>>> On Tue, Aug 6, 2019 at 8:50 PM Hesham Almatary <
> >>>>>> Hi Vaibhav,
> >>>>>> * I recommend you use rv64* because of a potential 32-bit HTIF
> issue on Spike.
> >>>>>> * Make sure you install Spike correctly [1] and it's in your path or
> >>>>>> also qemu-system-riscv* instead.
> >>>>>> * If you're building RTEMS for Spike (i.e., rv*_spike), make sure to
> >>>>>> add RISCV_ENABLE_HTIF_SUPPORT to your configure line [2] when you
> >>>>>> build RTEMS.
> >>>>>> * It might be easier to try rv64* on QEMU (i.e., no Spike) instead.
> >>>>>> [1] https://github.com/riscv/riscv-isa-sim
> >>>>>> [2]
> https://docs.rtems.org/branches/master/user/bsps/bsps-riscv.html
> >>>>>> On Tue, 6 Aug 2019 at 14:52, Vaibhav Gupta <
> >>>>>> > I am getting following error:
> >>>>>> > $ rtems-test --rtems-bsp=rv32imac_spike
> --rtems-tools=$HOME/development/rtems/5
> ~/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples
> >>>>>> > RTEMS Testing - Tester, 5.0.not_released
> >>>>>> >  Command Line: /home/varodek/development/rtems/5/bin/rtems-test
> --rtems-bsp=rv32imac_spike --rtems-tools=/home/varodek/development/rtems/5
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples
> >>>>>> >  Host: Linux varodek 5.0.9-arch1-1-ARCH #1 SMP PREEMPT Sat Apr 20
> 15:00:46 UTC 2019 x86_64
> >>>>>> >  Python: 3.7.3 (default, Mar 26 2019, 21:43:19) [GCC 8.2.1
> 20181127]
> >>>>>> > Host: Linux-5.0.9-arch1-1-ARCH-x86_64-with-arch (Linux varodek
> 5.0.9-arch1-1-ARCH #1 SMP PREEMPT Sat Apr 20 15:00:46 UTC 2019 x86_64 )
> >>>>>> > [ 2/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
> riscv32/rv32imac: capture.exe
> >>>>>> > [ 3/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
> riscv32/rv32imac: cdtest.exe
> >>>>>> > [ 4/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
> riscv32/rv32imac: cxx_iostream.exe
> >>>>>> > [ 1/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
> riscv32/rv32imac: base_sp.exe
> >>>>>> > error: spike.cfg:58: execute failed: spike --isa=RV32IMAC
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/capture.exe:
> exit-code:2
> exit-code:2
> >>>>>> > warning: switched to dry run due to errors
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/cxx_iostream.exe:
> exit-code:2
> exit-code:2
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/cdtest.exe:
> exit-code:2
> exit-code:2
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/base_sp.exe:
> exit-code:2
> exit-code:2
> >>>>>> > Result: invalid    Time: 0:00:00.032377 base_sp.exe
> >>>>>> > =>  run: spike --isa=RV32IMAC
> >>>>>> > Result: invalid    Time: 0:00:00.037950 capture.exe
> >>>>>> > Result: invalid    Time: 0:00:00.038061 cdtest.exe
> >>>>>> > Result: invalid    Time: 0:00:00.034353 cxx_iostream.exe
> >>>>>> > [ 7/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  |
> riscv32/rv32imac: minimum.exe
> >>>>>> > [ 8/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  |
> riscv32/rv32imac: nsecs.exe
> >>>>>> > [ 5/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  |
> riscv32/rv32imac: fileio.exe
> >>>>>> > [ 6/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  |
> riscv32/rv32imac: hello.exe
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/minimum.exe:
> exit-code:2
> exit-code:2
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/nsecs.exe:
> exit-code:2
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/fileio.exe:
> exit-code:2
> exit-code:2
> exit-code:2
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/hello.exe:
> exit-code:2
> exit-code:2
> >>>>>> > Result: invalid    Time: 0:00:00.009235 fileio.exe
> >>>>>> > Result: invalid    Time: 0:00:00.005886 hello.exe
> >>>>>> > Result: invalid    Time: 0:00:00.011045 nsecs.exe
> >>>>>> > [ 9/11] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:7  W:0  |
> riscv32/rv32imac: paranoia.exe
> >>>>>> > [10/11] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:7  W:0  |
> riscv32/rv32imac: ticker.exe
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/paranoia.exe:
> exit-code:2
> exit-code:2
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/ticker.exe:
> exit-code:2
> exit-code:2
> >>>>>> > [11/11] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:8  W:0  |
> riscv32/rv32imac: unlimited.exe
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/unlimited.exe:
> exit-code:2
> exit-code:2
> >>>>>> > Result: invalid    Time: 0:00:00.011650 paranoia.exe
> >>>>>> > Result: invalid    Time: 0:00:00.009872 ticker.exe
> >>>>>> > Result: invalid    Time: 0:00:00.002352 unlimited.exe
> >>>>>> > Passed:         1
> >>>>>> > Failed:         0
> >>>>>> > User Input:     0
> >>>>>> > Expected Fail:  0
> >>>>>> > Indeterminate:  0
> >>>>>> > Benchmark:      0
> >>>>>> > Timeout:        0
> >>>>>> > Invalid:       10
> >>>>>> > Wrong Version:  0
> >>>>>> > Wrong Build:    0
> >>>>>> > Wrong Tools:    0
> >>>>>> > Total:         11
> >>>>>> > Invalid:
> >>>>>> >  capture.exe
> >>>>>> >  cdtest.exe
> >>>>>> >  cxx_iostream.exe
> >>>>>> >  base_sp.exe
> >>>>>> >  nsecs.exe
> >>>>>> >  fileio.exe
> >>>>>> >  hello.exe
> >>>>>> >  paranoia.exe
> >>>>>> >  ticker.exe
> >>>>>> >  unlimited.exe
> >>>>>> > Average test time: 0:00:00.093749
> >>>>>> > Testing time     : 0:00:01.031239
> >>>>>> > _______________________________________________
> >>>>>> > devel mailing list
> >>>>>> > devel at rtems.org
> >>>>>> > http://lists.rtems.org/mailman/listinfo/devel
> >>> devel mailing list
> >>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190812/26fb6a23/attachment-0002.html>
