GSoC Project | Basic Support for Trace Compass
Ravindra Kumar Meena
rmeena840 at gmail.com
Tue Aug 6 11:26:31 UTC 2019
> > Yes, I tried that also. I can't see the 8 char for multiple
> > RTEMS_RECORD_THREAD_NAME in print_item(). Still, I tried to follow the
> > previously mentioned algorithm.
> https://github.com/rmeena840/rtems-tools/commit/33c217642e36b91926dfd823e5b3b59974790084
> The code is more complicated than necessary, but it looks mostly all right.
All variables are defined inside if()..else() scope. It can be made easy if
we use global variables. You asked once not to use global variables. So I
did in this way.
> Setting
> + cctx->thread_id_name[ item->cpu ].name_index = 0;
> if the name_index was 1, is wrong. You have to increment it.
Done
https://github.com/rmeena840/rtems-tools/commit/8ceb3ccb97422044fb30b3c562fc736cf0686d48
*Ravindra Kumar Meena*,
B. Tech. Computer Science and Engineering,
Indian Institute of Technology (Indian School of Mines)
<https://www.iitism.ac.in/>, Dhanbad
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190806/90cff1bc/attachment.html>
