GSoC Project | Basic Support for Trace Compass
Tue Aug 6 11:36:56 UTC 2019
On 06/08/2019 13:26, Ravindra Kumar Meena wrote:
>      > Yes, I tried that also. I can't see the 8 char for multiple
>      > RTEMS_RECORD_THREAD_NAME in print_item(). Still, I tried to
>     follow the
>      > previously mentioned algorithm.
>     https://github.com/rmeena840/rtems-tools/commit/33c217642e36b91926dfd823e5b3b59974790084
>     The code is more complicated than necessary, but it looks mostly all
>     right.
> All variables are defined inside if()..else() scope. It can be made easy
> if we use global variables. You asked once not to use global variables.
> So I did in this way.
For now this is all right, we will work on optimizations once the thread
names show up in the Trace Compass.
>     Setting
>     +        cctx->thread_id_name[ item->cpu ].name_index = 0;
>     if the name_index was 1, is wrong. You have to increment it.
> Done
> https://github.com/rmeena840/rtems-tools/commit/8ceb3ccb97422044fb30b3c562fc736cf0686d48
Ok, good. Now please use this table to populate the thread names in the
sched_switch event.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
