Not able to run riscv-rv32imac testsuites
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Tue Aug 6 11:29:25 UTC 2019
On Tue, Aug 6, 2019 at 2:36 PM Sebastian Huber <
> On 06/08/2019 10:54, Vaibhav Gupta wrote:
> > Getting this error:
> > $ rtems-test --rtems-bsp=rv32imac
> > --rtems-tools=$HOME/development/rtems/5
> ~/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples
> > RTEMS Testing - Tester, 5.0.not_released
> > Command Line: /home/varodek/development/rtems/5/bin/rtems-test
> > --rtems-bsp=rv32imac --rtems-tools=/home/varodek/development/rtems/5
> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples
> > Host: Linux varodek 5.0.9-arch1-1-ARCH #1 SMP PREEMPT Sat Apr 20
> > 15:00:46 UTC 2019 x86_64
> > Python: 3.7.3 (default, Mar 26 2019, 21:43:19) [GCC 8.2.1 20181127]
> > Host: Linux-5.0.9-arch1-1-ARCH-x86_64-with-arch (Linux varodek
> > 5.0.9-arch1-1-ARCH #1 SMP PREEMPT Sat Apr 20 15:00:46 UTC 2019 x86_64 )
> > error: cannot find bsp configuration file: rv32imac.ini
> Ok, maybe you can try one of these:
> find -name '*rv*ini' | sort
Thanks, this worked.
> ./tester/rtems/testing/bsps/rv32iac_spike.ini
> ./tester/rtems/testing/bsps/rv32imac_spike.ini
> ./tester/rtems/testing/bsps/rv32imafc_spike.ini
> ./tester/rtems/testing/bsps/rv32imafdc_spike.ini
> ./tester/rtems/testing/bsps/rv32imafd_spike.ini
> ./tester/rtems/testing/bsps/rv32im_spike.ini
> ./tester/rtems/testing/bsps/rv32i_spike.ini
> ./tester/rtems/testing/bsps/rv64imac_medany_spike.ini
> ./tester/rtems/testing/bsps/rv64imac_spike.ini
> ./tester/rtems/testing/bsps/rv64imafdc_medany_spike.ini
> ./tester/rtems/testing/bsps/rv64imafdc_spike.ini
> ./tester/rtems/testing/bsps/rv64imafd_medany.ini
> ./tester/rtems/testing/bsps/rv64imafd_medany_spike.ini
> ./tester/rtems/testing/bsps/rv64imafd_spike.ini
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190806/5266f6f2/attachment-0001.html>
