Problem: RSB does no longer install stand-alone sis
    Jiri Gaisler
    jiri at gaisler.se
    Thu Aug  8 21:42:58 UTC 2019
RSB does not longer install the stand-alone version of sis. Even though the RSB log claims is does, the binary is not copied to the install location:
installing: sis-2.17-x86_64-linux-gnu-1 -> /opt/rtems/5    does nothing ....
There has been a few commits that changes the RSB install scripts but I am not able to see where it goes wrong. Maybe someone more enlightened than me could look at this.
Building sis as bare tool has that same problem. The binary is built but not installed:
rtems-source-builder/bare$ ../source-builder/sb-set-builder --prefix=/opt/rtems/5 devel/sis
RTEMS Source Builder - Set Builder, 5 (e5460e9ecb99)
Build Set: devel/sis
config: devel/sis-2-1.cfg
package: sis-2.17-x86_64-linux-gnu-1
building: sis-2.17-x86_64-linux-gnu-1
sizes: sis-2.17-x86_64-linux-gnu-1: 3.770MB (installed: 633.499KB)
cleaning: sis-2.17-x86_64-linux-gnu-1
reporting: devel/sis-2-1.cfg -> sis-2.17-x86_64-linux-gnu-1.txt
reporting: devel/sis-2-1.cfg -> sis-2.17-x86_64-linux-gnu-1.xml
Build Set: Time 0:00:04.271759
$ ls -l /opt/rtems/5/bin/*sis*
ls: cannot access '/opt/rtems/5/bin/*sis*': No such file or directory
