Problem: RSB does no longer install stand-alone sis
Fri Aug 9 00:34:35 UTC 2019
On 9/8/19 7:59 am, Gedare Bloom wrote:
> On Thu, Aug 8, 2019 at 3:53 PM Gedare Bloom <gedare at rtems.org> wrote:
>> I can confirm something is wrong. The install step does copy something
>> though, I get a tree like this:
>> /share/rtems/rsb:
>> sis-2.17-x86_64-linux-gnu-1.txt  sis-2.17-x86_64-linux-gnu-1.xml
>> I gave --log option to sb-set-builder. I can see the build compiled.
>> It looks like %clean is running before %copy. That looks suspicious to me.
> Nvm, I think that may be normal.  I don't have any more guesses at the moment!
Thanks for taking the time to look. I must have broken something. I will take a
look this weekend. Sorry about this.
>> On Thu, Aug 8, 2019 at 3:43 PM Jiri Gaisler <jiri at gaisler.se> wrote:
>>> RSB does not longer install the stand-alone version of sis. Even though the RSB log claims is does, the binary is not copied to the install location:
>>> installing: sis-2.17-x86_64-linux-gnu-1 -> /opt/rtems/5    does nothing ....
>>> There has been a few commits that changes the RSB install scripts but I am not able to see where it goes wrong. Maybe someone more enlightened than me could look at this.
>>> Building sis as bare tool has that same problem. The binary is built but not installed:
>>> rtems-source-builder/bare$ ../source-builder/sb-set-builder --prefix=/opt/rtems/5 devel/sis
>>> RTEMS Source Builder - Set Builder, 5 (e5460e9ecb99)
>>> Build Set: devel/sis
>>> config: devel/sis-2-1.cfg
>>> package: sis-2.17-x86_64-linux-gnu-1
>>> building: sis-2.17-x86_64-linux-gnu-1
>>> sizes: sis-2.17-x86_64-linux-gnu-1: 3.770MB (installed: 633.499KB)
>>> cleaning: sis-2.17-x86_64-linux-gnu-1
>>> reporting: devel/sis-2-1.cfg -> sis-2.17-x86_64-linux-gnu-1.txt
>>> reporting: devel/sis-2-1.cfg -> sis-2.17-x86_64-linux-gnu-1.xml
>>> Build Set: Time 0:00:04.271759
>>> $ ls -l /opt/rtems/5/bin/*sis*
>>> ls: cannot access '/opt/rtems/5/bin/*sis*': No such file or directory
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
