Problem: RSB does no longer install stand-alone sis
Jiri Gaisler jiri at gaisler.se
Sat Aug 10 13:17:04 UTC 2019
The problem comes from a commit to source-builder/config/sis-2-1.cfg,
made on July 23. If I revert that, installation works again. If nobody
objects, I will push a revert in about an hour and we can debug this at
a later stage.
Jiri.
On 8/9/19 2:34 AM, Chris Johns wrote:
> On 9/8/19 7:59 am, Gedare Bloom wrote:
>> On Thu, Aug 8, 2019 at 3:53 PM Gedare Bloom <gedare at rtems.org> wrote:
>>> I can confirm something is wrong. The install step does copy something
>>> though, I get a tree like this:
>>> /share/rtems/rsb:
>>> sis-2.17-x86_64-linux-gnu-1.txt  sis-2.17-x86_64-linux-gnu-1.xml
>>> I gave --log option to sb-set-builder. I can see the build compiled.
>>> It looks like %clean is running before %copy. That looks suspicious to me.
>> Nvm, I think that may be normal.  I don't have any more guesses at the moment!
> Thanks for taking the time to look. I must have broken something. I will take a
> look this weekend. Sorry about this.
> Chris
>>> On Thu, Aug 8, 2019 at 3:43 PM Jiri Gaisler <jiri at gaisler.se> wrote:
>>>> RSB does not longer install the stand-alone version of sis. Even though the RSB log claims is does, the binary is not copied to the install location:
>>>> installing: sis-2.17-x86_64-linux-gnu-1 -> /opt/rtems/5    does nothing ....
>>>> There has been a few commits that changes the RSB install scripts but I am not able to see where it goes wrong. Maybe someone more enlightened than me could look at this.
>>>> Building sis as bare tool has that same problem. The binary is built but not installed:
>>>> rtems-source-builder/bare$ ../source-builder/sb-set-builder --prefix=/opt/rtems/5 devel/sis
>>>> RTEMS Source Builder - Set Builder, 5 (e5460e9ecb99)
>>>> Build Set: devel/sis
>>>> config: devel/sis-2-1.cfg
>>>> package: sis-2.17-x86_64-linux-gnu-1
>>>> building: sis-2.17-x86_64-linux-gnu-1
>>>> sizes: sis-2.17-x86_64-linux-gnu-1: 3.770MB (installed: 633.499KB)
>>>> cleaning: sis-2.17-x86_64-linux-gnu-1
>>>> reporting: devel/sis-2-1.cfg -> sis-2.17-x86_64-linux-gnu-1.txt
>>>> reporting: devel/sis-2-1.cfg -> sis-2.17-x86_64-linux-gnu-1.xml
>>>> Build Set: Time 0:00:04.271759
>>>> $ ls -l /opt/rtems/5/bin/*sis*
>>>> ls: cannot access '/opt/rtems/5/bin/*sis*': No such file or directory
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
