GSoC Project | Basic Support for Trace Compass
Fri Aug 9 13:45:51 UTC 2019
----- Joel Sherrill <joel at rtems.org> schrieb:
> Coming in late but there isn't there a helper method to turn object names
> into strings from either 32 bit values or strings? Shouldn't that be used?
This program runs on the host.
> On Fri, Aug 9, 2019, 8:17 AM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
> > On 09/08/2019 15:06, Ravindra Kumar Meena wrote:
> > > rtems-main.c cleanup:
> > https://github.com/rmeena840/rtems-tools/commit/61d5dc45e43f0998ad9305d565926090215a5bdc
> > > Switch_event per CPU added:
> > https://github.com/rmeena840/rtems-tools/commit/8ffe8bd2adea27772a9ab0e578539dd99fa0174b
> > > Have a look.
> > Ok, good. Please always check if the babeltrace and Trace Compass give
> > the right results after the changes.
> > If you use cctx->switch_event[ item->cpu ] and similar a couple of times
> > in a function, then please assign it to a local pointer and use it, e.g.
> > switch_event *se = &cctx->switch_event[ item->cpu ];
> > Please check all structure names and make the similar to the names used
> > in the metadata, e.g. swich_event -> event_sched_switch;
> > Please check the style of the if again, it should be:
> > if ( condition ) {
> > } else {
> > Check the white space and position of the { }.
> > When you have a function like get_api_of_id() you return the api, so the
> > variable should be named "api":
> >    size_t api_id = get_api_of_id( cctx->thread_id_name[ item->cpu
> > ].thread_id );
> >    size_t api = get_api_of_id( cctx->thread_id_name[ item->cpu
> > ].thread_id );
> > Declare all variables at the top of the function, e.g.
> > size_t api;
> > api = get_api_of_id( cctx->thread_id_name[ item->cpu ].thread_id );
> > Sebastian Huber, embedded brains GmbH
> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
> > Phone   : +49 89 189 47 41-16
> > Fax     : +49 89 189 47 41-09
> > E-Mail  : sebastian.huber at embedded-brains.de
> > PGP     : Public key available on request.
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> > devel mailing list
> > devel at rtems.org
