GSoC Project | Basic Support for Trace Compass
Joel Sherrill
joel at rtems.org
Fri Aug 9 14:11:30 UTC 2019
On Fri, Aug 9, 2019, 8:45 AM Sebastian Huber <
> ----- Joel Sherrill <joel at rtems.org> schrieb:
> > Coming in late but there isn't there a helper method to turn object names
> > into strings from either 32 bit values or strings? Shouldn't that be
> used?
> This program runs on the host.
Couldn't the method be copied?
> > On Fri, Aug 9, 2019, 8:17 AM Sebastian Huber <
> > > On 09/08/2019 15:06, Ravindra Kumar Meena wrote:
> > > > rtems-main.c cleanup:
> https://github.com/rmeena840/rtems-tools/commit/61d5dc45e43f0998ad9305d565926090215a5bdc
> > > > Switch_event per CPU added:
> https://github.com/rmeena840/rtems-tools/commit/8ffe8bd2adea27772a9ab0e578539dd99fa0174b
> > > > Have a look.
> > > Ok, good. Please always check if the babeltrace and Trace Compass give
> > > the right results after the changes.
> > > If you use cctx->switch_event[ item->cpu ] and similar a couple of
> times
> > > in a function, then please assign it to a local pointer and use it,
> e.g.
> > > switch_event *se = &cctx->switch_event[ item->cpu ];
> > > Please check all structure names and make the similar to the names used
> > > in the metadata, e.g. swich_event -> event_sched_switch;
> > > Please check the style of the if again, it should be:
> > > if ( condition ) {
> > > } else {
> > > Check the white space and position of the { }.
> > > When you have a function like get_api_of_id() you return the api, so
> the
> > > variable should be named "api":
> > > size_t api_id = get_api_of_id( cctx->thread_id_name[ item->cpu
> > > ].thread_id );
> > > size_t api = get_api_of_id( cctx->thread_id_name[ item->cpu
> > > ].thread_id );
> > > Declare all variables at the top of the function, e.g.
> > > size_t api;
> > > api = get_api_of_id( cctx->thread_id_name[ item->cpu ].thread_id );
> > > Sebastian Huber, embedded brains GmbH
> > > Address : Dornierstr. 4, D-82178 Puchheim, Germany
> > > Phone : +49 89 189 47 41-16
> > > Fax : +49 89 189 47 41-09
> > > E-Mail : sebastian.huber at embedded-brains.de
> > > PGP : Public key available on request.
> > > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> > > _______________________________________________
> > > devel mailing list
> > > devel at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190809/10ab0095/attachment.html>
