GSoC Project | Basic Support for Trace Compass
Fri Aug 9 16:25:06 UTC 2019
----- Am 9. Aug 2019 um 16:11 schrieb joel joel at rtems.org:
> On Fri, Aug 9, 2019, 8:45 AM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> ----- Joel Sherrill <joel at rtems.org> schrieb:
>> > Coming in late but there isn't there a helper method to turn object names
>> > into strings from either 32 bit values or strings? Shouldn't that be
>> used?
>> This program runs on the host.
> Couldn't the method be copied?
Yes, you are a bit late ;-)
The integer values with the thread name parts are in the record event data, not the object names.
