GSoC 2019: POSIX Compliance - FENV Environment probably not working properly in RISCV
Joel Sherrill
joel at rtems.org
Wed Aug 14 11:44:04 UTC 2019
Thank you.
Do you see anything wrong with the riscv fenv implementation? His program
runs under Linux and hangs on both Qemu and sis.
On Wed, Aug 14, 2019, 2:18 AM Jiri Gaisler <jiri at gaisler.se> wrote:
> I have attached the sis manual. Page 17:
> "SIS can be connected to gdb through a network socket using the gdb remote interface.
> Either start SIS with -gdb, or issue the ’gdb’ command inside SIS, and connect gdb with
> ’target extended-remote localhost:1234’. The port can be changed using the -port option."
> You still need all other options, so to start on a windows host do:
> $ riscv-rtems-sis -riscv -nouartrx -gdb
> To start gdb, do:
> $ riscv-rtems-gdb app.exe
> (gdb) target extended-remote localhost:1234
> (gdb) load
> (gdb) run
> To re-run the application, issue a new load command first.
> Regards, Jiri.
> On 8/14/19 12:37 AM, Vaibhav Gupta wrote:
> On Wed, Aug 14, 2019 at 4:04 AM Joel Sherrill <joel at rtems.org> wrote:
>> On Tue, Aug 13, 2019 at 5:09 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
>> wrote:
>>> On Mon, Aug 12, 2019 at 11:50 PM Joel Sherrill <joel at rtems.org> wrote:
>>>> Can you post or email me privately the full patch? I can try to see
>>>> what I spot.
>>> I have sent you the patch.
>>>> Can you check with objdump or gdb that the methods which don't appear
>>>> to work
>>>> are actually the RISC-V implementation? Look at the disassembly and see
>>>> if it
>>>> looks like you expect.
>>> I am exploring for this.
>> Since I don't know how to attach gdb to the new sis for griscv, I emailed
>> Jiri privately.
>> Your program works as expected on Linux. Perhaps Jiri has some advice for
>> my
>> debugging setup ignorance and fenv on RISC-V.
> Okay, I will wait. Till then I can work with porting for other
> architecture. :)
>> Do you happen to have fenv support for another architecture queued up? It
>> would be
>> interesting to see if it works on other targets.
> Yup, they were in my to do list. Till testsuite method is solved, I will
> work on them now.
> - Vaibhav Gupta
>> --joel
>>> - Vaibhav Gupta
>>>> Does this require a patch to newlib as well?
>>>> --joel
>>>> On Sun, Aug 11, 2019 at 10:49 AM Vaibhav Gupta <
>>>> vaibhavgupta40 at gmail.com> wrote:
>>>>> Configure command I used to build BSP:
>>>>> $ /home/varodek/development/rtems/kernel/rtems/configure
>>>>> --prefix=/home/varodek/development/rtems/5 --enable-maintainer-mode
>>>>> --target=riscv-rtems5 --enable-rtemsbsp=rv32imac --enable-tests
>>>>> --enable-posix --disable-networking --enable-cxx RISCV_ENABLE_HTIF_SUPPORT=1
>>>>> Qemu command I used to run test:
>>>>> $ qemu-system-riscv32 -no-reboot -nographic -machine virt -m 256M
>>>>> -kernel psxfenv01.exe
>>>>> Makefile.am
>>>>> + if TEST_psxfenv01
>>>>> + psx_tests += psxfenv01
>>>>> + psxfenv01_SOURCES = psxfenv01/init.c
>>>>> + psxfenv01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxfenv01) \
>>>>> + $(support_includes)
>>>>> + psxfenv01_LDADD = -lm $(LDADD)
>>>>> + endif
>>>>> On Sun, Aug 11, 2019 at 8:36 PM Vaibhav Gupta <
>>>>>> My code of testsuite:
>>>>>> /* Test 'FE_DIVBYZERO' */
>>>>>> puts( "\nDivide by zero and confirm fetestexcept()." );
>>>>>> a = 0.0;
>>>>>> b = 1.0;
>>>>>> c = b/a;
>>>>>> printf("\n%d",FE_DIVBYZERO);
>>>>>> fegetexceptflag(&excepts,FE_ALL_EXCEPT);
>>>>>> printf("\n%d",excepts);
>>>>>> r = feraiseexcept(FE_DIVBYZERO);
>>>>>> printf("\n%d\n",r);
>>>>>> rtems_test_assert( fetestexcept( FE_DIVBYZERO ) );
>>>>>> OUTPUT
>>>>>> 8
>>>>>> 0
>>>>>> 1
>>>>>> /home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/psxtests/psxfenv01/init.c:
>>>>>> 84 fetestexcept( FE_DIVBYZERO )
>>>>>> EXPECTED OUTPUT
>>>>>> 8
>>>>>> 8
>>>>>> 0
>>>>>> - fetestexcept( FE_DIVBYZERO ), should return a non-zero value as
>>>>>> division-by-zero was performed.
>>>>>> - feraiseexcept(FE_DIVBYZERO); is also not working. It should return
>>>>>> zero when successful
>>>>>> Thank You
>>>>>> Vaibhav Gupta
>>>>>> _______________________________________________
>>>>> devel mailing list
>>>>> devel at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/devel
> devel mailing listdevel at rtems.orghttp://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190814/0a111e80/attachment-0001.html>
