GSoC 2019 : POSIX Compliance - Final Report
Tue Aug 20 16:01:24 UTC 2019
I am late to the party. I made a couple of small changes directly to
the document.
I encourage you continue to pick at getting the other fenv ports into
newlib. As you
hopefully saw from me adding the stubs for fenv methods and documentation,
things moving slowly were not a reflection on you personally. I
certainly went through
a number of rounds. :)
Could you add a complete list of POSIX methods that you added? I need to update
the spreadsheet and .csv file in the POSIX Compliance document.
--joel
On Fri, Aug 16, 2019 at 10:48 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
> Made the changes as suggested :)
> Please have a look at this now. If every thing is fine.
> I will publish it in my blog.
> -Vaibhav Gupta
> On Fri, Aug 16, 2019 at 7:57 PM Gedare Bloom <gedare at rtems.org> wrote:
>> Vaibhav,
>> Please add a subsection near the top that consolidates links to all
>> the code you wrote during the summer. It is great to have them in
>> context, but it should also be easy (~10 seconds) to find what code
>> you wrote.
>> On Thu, Aug 15, 2019 at 1:27 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
>> > Hello,
>> > I have made the draft of my project report on google docs.
>> > I have mentioned about each and every task completed
>> > and which are in progress.
>> > It would be very helpful for me If I can get reviews on this,
>> > will also make required changes.
>> > https://docs.google.com/document/d/1I3FsA0whd2AcLKdagUzins-JmWv1QTC6-0v0uvS1_7k/edit?usp=sharing
>> > Thank You
>> > Vaibhav Gupta
