LTTng sched_switch documentation patch
Ravindra Kumar Meena
rmeena840 at gmail.com
Fri Aug 30 06:58:45 UTC 2019
Hello Chris and Sebastian,
I have attached the updated LTTng sched_switch documentation patch(v5).
This one is a whole single patch.
Please review the attached patch.
*What changed from v4 to v5:*
* rtems-record-lttng tool is now available via RSB. So for the same, I have
updated the patch.
* I have removed the Trace Compass screen capture.
* I have REST numbering format.
* Removed the telent command. Telnet is not required for tracing.
* set the code block type to shell.
* Added few lines for raw-data.
Thanks
*Ravindra Kumar Meena*,
B. Tech. Computer Science and Engineering,
Indian Institute of Technology (Indian School of Mines)
<https://www.iitism.ac.in/>, Dhanbad
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190830/f7c1f93d/attachment-0001.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190830/f7c1f93d/attachment-0001.obj>
