[PATCH] record: Allow tracing of ISR disable/enable
    Sebastian Huber
    Fri Aug 30 07:01:38 UTC 2019
Directly use the CPU port API in boot_card() to allow tracing of the
higher level interrupt disable/enable routines, e.g.
_ISR_Local_disable() and _ISR_Local_enable().  Currently, there is no
configuration option to enable this.  Below is a patch.  It may be used
to investigate some nasty low level bugs in the system.
Update #3665.
diff --git a/cpukit/include/rtems/score/isrlevel.h b/cpukit/include/rtems/score/isrlevel.h
index c42451d010..46d361ddc2 100644
--- a/cpukit/include/rtems/score/isrlevel.h
+++ b/cpukit/include/rtems/score/isrlevel.h
@@ -40,6 +40,10 @@ extern "C" {
 typedef uint32_t   ISR_Level;
+uint32_t rtems_record_interrupt_disable( void );
+void rtems_record_interrupt_enable( uint32_t level );
  *  @brief Disables interrupts on this processor.
@@ -56,8 +60,7 @@ typedef uint32_t   ISR_Level;
 #define _ISR_Local_disable( _level ) \
   do { \
-    _CPU_ISR_Disable( _level ); \
-    RTEMS_COMPILER_MEMORY_BARRIER(); \
+    _level = rtems_record_interrupt_disable(); \
   } while (0)
@@ -72,10 +75,7 @@ typedef uint32_t   ISR_Level;
  *  _ISR_Local_disable().
 #define _ISR_Local_enable( _level ) \
-  do { \
-    _CPU_ISR_Enable( _level ); \
-  } while (0)
+  rtems_record_interrupt_enable( _level )
  *  @brief Temporarily enables interrupts on this processor.
@@ -98,9 +98,8 @@ typedef uint32_t   ISR_Level;
 #define _ISR_Local_flash( _level ) \
   do { \
-    _CPU_ISR_Flash( _level ); \
+    rtems_record_interrupt_enable( _level ); \
   } while (0)
 bsps/shared/start/bootcard.c | 8 +++++---
 1 file changed, 5 insertions(+), 3 deletions(-)
diff --git a/bsps/shared/start/bootcard.c b/bsps/shared/start/bootcard.c
index 542785bd83..a6ad1953c0 100644
--- a/bsps/shared/start/bootcard.c
+++ b/bsps/shared/start/bootcard.c
@@ -46,13 +46,15 @@ void boot_card(
   const char *cmdline
-  rtems_interrupt_level  bsp_isr_level;
+  ISR_Level bsp_isr_level;
-   *  Make sure interrupts are disabled.
+   * Make sure interrupts are disabled.  Directly use the CPU port API to allow
+   * tracing of the higher level interrupt disable/enable routines, e.g.
+   * _ISR_Local_disable() and _ISR_Local_enable().
+  _CPU_ISR_Disable( bsp_isr_level );
   (void) bsp_isr_level;
-  rtems_interrupt_local_disable( bsp_isr_level );
   bsp_boot_cmdline = cmdline;
2.16.4
