RISCV BSP
Vaibhav Gupta vaibhavgupta40 at gmail.com
Fri Aug 2 16:27:10 UTC 2019
Thanks a lot.
Then I will be working with "rv32imac" and "rv64imac"
Vaibhav Gupta
On Fri, Aug 2, 2019 at 1:33 PM Sebastian Huber <
> On 02/08/2019 09:50, Vaibhav Gupta wrote:
> > Hello,
> > I was about to test the testsuite code, need to confirm
> > on which RISCV BSP we are going to work?
> > For example, for ARM I was asked for xilinx-zynq
> > So is there any specific one for riscv too, or should I build any of it?
> While you work on this, please review the documentation.
> https://docs.rtems.org/branches/master/user/bsps/bsps-riscv.html
> Feel free to send documentation patches. There is support for some
> RISC-V BSPs in the RTEMS Tester:
> ./tester/rtems/testing/bsps/griscv-sis.ini
> ./tester/rtems/testing/bsps/griscv.ini
> ./tester/rtems/testing/bsps/griscv-sis-cov.ini
> ./tester/rtems/testing/bsps/rv32imac_spike.ini
> ./tester/rtems/testing/bsps/rv64imafdc_spike.ini
> ./tester/rtems/testing/bsps/rv64imafd_spike.ini
> ./tester/rtems/testing/bsps/rv64imafd_medany.ini
> ./tester/rtems/testing/bsps/rv64imafd_medany_spike.ini
> ./tester/rtems/testing/bsps/rv32imafc_spike.ini
> ./tester/rtems/testing/bsps/rv32imafd_spike.ini
> ./tester/rtems/testing/bsps/rv64imac_medany_spike.ini
> ./tester/rtems/testing/bsps/rv32im_spike.ini
> ./tester/rtems/testing/bsps/rv64imac_spike.ini
> ./tester/rtems/testing/bsps/rv32imafdc_spike.ini
> ./tester/rtems/testing/bsps/rv32iac_spike.ini
> ./tester/rtems/testing/bsps/rv64imafdc_medany_spike.ini
> ./tester/rtems/testing/bsps/rv32i_spike.ini
> I would test on a 32-bit and 64-bit variant. Also with hardware FP and
> without.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190802/8fdfbd96/attachment-0002.html>
