[RSB PATCH v2] Disable built-in sis in gdb.
Jiri Gaisler
jiri at gaisler.se
Thu Aug 8 22:06:40 UTC 2019
On 8/8/19 11:48 PM, Joel Sherrill wrote:
> Unless it causes an issue, I would really like to leave sis enabled inside gdb. It really is such a nice environment to debug.
Stand-alone sis has a gdb server, so the gdb debug environment should be identical. In gdb, just do target extended-remote localhost:1234 instead of target sim. Keeping sis inside gdb has a number of problems:
* The sis patches will never be accepted into the gdb mainline
* We will have to maintain a patch set for each gdb version
* Making new versions of sis is cumbersome since we have to provided patches rather than just a git repo
* No support for data watchpoints in the gdb sim interface
* Build problems for Cygwin
I also like the simplicity of a built-in simulator, but a stand-alone sim is just so much easier to develop and maintain...
> On Thu, Aug 8, 2019, 4:47 PM Jiri Gaisler <jiri at gaisler.se <mailto:jiri at gaisler.se>> wrote:
> This time it also works on RISC-V ... :-)
> devel mailing list
> devel at rtems.org <mailto:devel at rtems.org>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190809/d67cc2fc/attachment-0002.html>
