[RSB PATCH v2] Disable built-in sis in gdb.
Thu Aug 8 23:13:07 UTC 2019
On Thu, Aug 8, 2019, 5:06 PM Jiri Gaisler <jiri at gaisler.se> wrote:
> On 8/8/19 11:48 PM, Joel Sherrill wrote:
> Unless it causes an issue, I would really like to leave sis enabled inside
> gdb. It really is such a nice environment to debug.
> Stand-alone sis has a gdb server, so the gdb debug environment should be
> identical. In gdb, just do target extended-remote localhost:1234 instead of
> target sim. Keeping sis inside gdb has a number of problems:
> * The sis patches will never be accepted into the gdb mainline
> * We will have to maintain a patch set for each gdb version
> * Making new versions of sis is cumbersome since we have to provided
> patches rather than just a git repo
> * No support for data watchpoints in the gdb sim interface
> * Build problems for Cygwin
> I also like the simplicity of a built-in simulator, but a stand-alone sim
> is just so much easier to develop and maintain...
I give. :)
> On Thu, Aug 8, 2019, 4:47 PM Jiri Gaisler <jiri at gaisler.se> wrote:
>> This time it also works on RISC-V ... :-)
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190808/7e44798e/attachment-0002.html>
