Not able to run riscv-rv32imac testsuites
Vaibhav Gupta vaibhavgupta40 at gmail.com
Fri Aug 9 09:23:10 UTC 2019
I was able to run rv32imac using
qemu-system-riscv32 -no-reboot -nographic -machine virt -m 256M
-kernel hello.exe
On Tue, Aug 6, 2019 at 9:04 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
wrote:
> Awesome, thanks!
> On Tue, Aug 6, 2019 at 8:50 PM Hesham Almatary <
> hesham.almatary at cl.cam.ac.uk> wrote:
>> Hi Vaibhav,
>> * I recommend you use rv64* because of a potential 32-bit HTIF issue on
>> Spike.
>> * Make sure you install Spike correctly [1] and it's in your path or
>> also qemu-system-riscv* instead.
>> * If you're building RTEMS for Spike (i.e., rv*_spike), make sure to
>> add RISCV_ENABLE_HTIF_SUPPORT to your configure line [2] when you
>> build RTEMS.
>> * It might be easier to try rv64* on QEMU (i.e., no Spike) instead.
>> [1] https://github.com/riscv/riscv-isa-sim
>> [2] https://docs.rtems.org/branches/master/user/bsps/bsps-riscv.html
>> On Tue, 6 Aug 2019 at 14:52, Vaibhav Gupta <vaibhavgupta40 at gmail.com>
>> wrote:
>> > I am getting following error:
>> > $ rtems-test --rtems-bsp=rv32imac_spike
>> --rtems-tools=$HOME/development/rtems/5
>> ~/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples
>> > RTEMS Testing - Tester, 5.0.not_released
>> >  Command Line: /home/varodek/development/rtems/5/bin/rtems-test
>> --rtems-bsp=rv32imac_spike --rtems-tools=/home/varodek/development/rtems/5
>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples
>> >  Host: Linux varodek 5.0.9-arch1-1-ARCH #1 SMP PREEMPT Sat Apr 20
>> 15:00:46 UTC 2019 x86_64
>> >  Python: 3.7.3 (default, Mar 26 2019, 21:43:19) [GCC 8.2.1 20181127]
>> > Host: Linux-5.0.9-arch1-1-ARCH-x86_64-with-arch (Linux varodek
>> 5.0.9-arch1-1-ARCH #1 SMP PREEMPT Sat Apr 20 15:00:46 UTC 2019 x86_64 )
>> > [ 2/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
>> riscv32/rv32imac: capture.exe
>> > [ 3/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
>> riscv32/rv32imac: cdtest.exe
>> > [ 4/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
>> riscv32/rv32imac: cxx_iostream.exe
>> > [ 1/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:0  W:0  |
>> riscv32/rv32imac: base_sp.exe
>> > error: spike.cfg:58: execute failed: spike --isa=RV32IMAC
>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/capture.exe:
>> exit-code:2
>> exit-code:2
>> > warning: switched to dry run due to errors
>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/cxx_iostream.exe:
>> exit-code:2
>> exit-code:2
>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/cdtest.exe:
>> exit-code:2
>> exit-code:2
>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/base_sp.exe:
>> exit-code:2
>> exit-code:2
>> > Result: invalid    Time: 0:00:00.032377 base_sp.exe
>> > =>  run: spike --isa=RV32IMAC
>> > Result: invalid    Time: 0:00:00.037950 capture.exe
>> > Result: invalid    Time: 0:00:00.038061 cdtest.exe
>> > Result: invalid    Time: 0:00:00.034353 cxx_iostream.exe
>> > [ 7/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  |
>> riscv32/rv32imac: minimum.exe
>> > [ 8/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  |
>> riscv32/rv32imac: nsecs.exe
>> > [ 5/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  |
>> riscv32/rv32imac: fileio.exe
>> > [ 6/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  i:4  W:0  |
>> riscv32/rv32imac: hello.exe
>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/minimum.exe:
>> exit-code:2
>> exit-code:2
>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/nsecs.exe:
>> exit-code:2
>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/fileio.exe:
>> exit-code:2
>> exit-code:2
>> exit-code:2
>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/hello.exe:
>> exit-code:2
>> exit-code:2
>> > Result: invalid    Time: 0:00:00.009235 fileio.exe
>> > Result: invalid    Time: 0:00:00.005886 hello.exe
>> > Result: invalid    Time: 0:00:00.011045 nsecs.exe
>> > [ 9/11] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:7  W:0  |
>> riscv32/rv32imac: paranoia.exe
>> > [10/11] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:7  W:0  |
>> riscv32/rv32imac: ticker.exe
>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/paranoia.exe:
>> exit-code:2
>> exit-code:2
>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/ticker.exe:
>> exit-code:2
>> exit-code:2
>> > [11/11] p:1  f:0  u:0  e:0  I:0  B:0  t:0  i:8  W:0  |
>> riscv32/rv32imac: unlimited.exe
>> /home/varodek/development/rtems/kernel/rv32imac/riscv-rtems5/c/rv32imac/testsuites/samples/unlimited.exe:
>> exit-code:2
>> exit-code:2
>> > Result: invalid    Time: 0:00:00.011650 paranoia.exe
>> > Result: invalid    Time: 0:00:00.009872 ticker.exe
>> > Result: invalid    Time: 0:00:00.002352 unlimited.exe
>> > Passed:         1
>> > Failed:         0
>> > User Input:     0
>> > Expected Fail:  0
>> > Indeterminate:  0
>> > Benchmark:      0
>> > Timeout:        0
>> > Invalid:       10
>> > Wrong Version:  0
>> > Wrong Build:    0
>> > Wrong Tools:    0
>> > Total:         11
>> > Invalid:
>> >  capture.exe
>> >  cdtest.exe
>> >  cxx_iostream.exe
>> >  base_sp.exe
>> >  nsecs.exe
>> >  fileio.exe
>> >  hello.exe
>> >  paranoia.exe
>> >  ticker.exe
>> >  unlimited.exe
>> > Average test time: 0:00:00.093749
>> > Testing time     : 0:00:01.031239
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190809/4da8d610/attachment-0002.html>
